727 clutch kit's #1461297
07/01/13 08:24 PM
07/01/13 08:24 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok so I have to install a clutch kit an steele's in my 727, my question is want's a good yet cheap 1 to go with?? I heard that the ATC Pro King kit is pretty good an the ATP Automatic Transmission Master Repair kit from summit racing is good. I don't need a whole kit just the clutch's an steele's but I think ya can only buy a whole kit right?? I got about $80.00 to spend (budget build) if ya got some other brand's or link's please let me know thank's
drive fast, drive hard, DRIVE MOPAR
Re: 727 clutch kit's [Re: lifted85] #1461298
07/01/13 09:16 PM
07/01/13 09:16 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Re: 727 clutch kit's [Re: goldmember] #1461299
07/01/13 09:20 PM
07/01/13 09:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
In Seattle area there's Pat Blais:
206-365-1966
tflitepatty@comcast.net
Ebay store T'Flite Patty's Shop Mart
Good guy, very reasonable, knows his stuff
Re: 727 clutch kit's [Re: topside] #1461300
07/01/13 10:25 PM
07/01/13 10:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: 727 clutch kit's [Re: 70AARcuda] #1461301
07/02/13 02:55 AM
07/02/13 02:55 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
how do I know the clutch thickness?? im now a auto tran's guy, im not sure how many clutch's or steele's are even in a 727, so im at a loss buying the part's separate any 1 help me on this 1 lol..
Re: 727 clutch kit's [Re: lifted85] #1461302
07/02/13 03:26 AM
07/02/13 03:26 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
take the clutch pac apart and count them...
and get a digital caliper on the disc to measure thickness..
https://www.wittrans.com/Schematic.aspx?Transmission=A727
Tony
Re: 727 clutch kit's [Re: lifted85] #1461303
07/02/13 05:20 AM
07/02/13 05:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If your pulling the trans apart, replace the seals too. There are usually some good deals on E-Bay with kits that include the pump and output bushings, bands and different grades of clutch/steels.
bulkpart.com has good prices too, but I have had them mess up some orders in the past.
Re: 727 clutch kit's [Re: lifted85] #1461304
07/02/13 09:41 AM
07/02/13 09:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
We can't see what transmission you actually have from where most of us sit so that request is pretty much impossible.
Re: 727 clutch kit's [Re: JohnRR] #1461305
07/02/13 10:09 AM
07/02/13 10:09 AM
scratchnfotraction Offline
order a full rebuild kit from John Cope at CRT.
runs about 90$ for a full rebuild kit with clutches and steels.
Re: 727 clutch kit's [Re: scratchnfotraction] #1461306
07/02/13 12:46 PM
07/02/13 12:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=9102
That's usually a decent start and basically the same thing that everyone else tends to sell.
Re: 727 clutch kit's [Re: scratchnfotraction] #1461307
07/03/13 09:48 AM
07/03/13 09:48 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you might be able to save a few bucks buying from one of those bulk distribution centers but for the money you save(whitch aint much)your still left on your own.buy from John Cope and you not only get the RIGHT parts but he,s always very eager to answer any ?,s you have during your rebuild,that alone is pricless.
Re: 727 clutch kit's [Re: scratchnfotraction] #1461308
07/03/13 04:14 PM
07/03/13 04:14 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
no front band..no bushing..no thrust washers...
add those to the cost ...
transtar kit comes with front band..thrust washers..and pump, drum, and tail shaft bushing.
if i had that trans apart i would rebuild it...if the clutch disc need replacement ..probably all the sealing rings are shot...
727 is a pretty simple trans to rebuild..
Tony
Re: 727 clutch kit's [Re: 70AARcuda] #1461309
07/03/13 04:40 PM
07/03/13 04:40 PM
RobX4406 Offline
RobX4406  Offline
I forgot about the black magic required to build a 904 or 727.
