What converter is this? #1461269
07/01/13 06:45 PM
07/01/13 06:45 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
All I know is that it a 360 converter. It measures 11 3/16 inches. What stall could it have?
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: What converter is this? [Re: HP2] #1461270
07/01/13 06:49 PM
07/01/13 06:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
picture did not work...
any numbers stamped on converter?
Tony
70 AARCuda Vitamin C
Re: What converter is this? [Re: HP2] #1461271
07/01/13 07:21 PM
07/01/13 07:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Where are you measuring it? If you're measuring it across the bolt holes it's a 12" converter......stall speed will depend on the power input.
Re: What converter is this? [Re: John_Kunkel] #1461272
07/01/13 07:51 PM
07/01/13 07:51 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I measured the outer diameter. I want a converter for a 360, would guess around 320-340hp.
Trying to upload the pic again.
71 Duster 340
Re: What converter is this? [Re: 70AARcuda] #1461273
07/01/13 07:53 PM
07/01/13 07:53 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I couldn't find any number. Where should I look?
71 Duster 340
Re: What converter is this? [Re: HP2] #1461274
07/02/13 02:38 PM
07/02/13 02:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure across the bolt holes, if it measures 10" it's an 11" converter if it measures 11 1/8" it's a 12" converter.
There's no way to tell the stall speed by looking.
Re: What converter is this? [Re: John_Kunkel] #1461275
07/02/13 05:32 PM
07/02/13 05:32 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If you want one for a 360 first thing you need to do is make sure it has the extra balancing weights on it. There should be two weights tack welded to the front of it. Typically the 360 ones will have what looks like a larger starter ring and are supposed to be about 1800 from what I can remember. That looks like a 318 to me...maybe 1200 stall??????
...FAFO...
Re: What converter is this? [Re: skicker] #1461276
07/02/13 09:12 PM
07/02/13 09:12 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
The big weights are there so It should be a 360.
71 Duster 340
