Bead Blaster Window Protector? #1460630
06/30/13 11:41 PM
06/30/13 11:41 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I have owned a harbor freight table top bead blaster for some time. The unit came with a thin plastic film affixed to the window. That film became etched and I removed it. I assume that I need to replace it so as to not etch the glass. Harbor freight guys look at me cross eyed when I ask if they have replacements.
Anyone know what material to use and where to get it?
I’m listening.
Re: Bead Blaster Window Protector? [Re: Big Bad Bee] #1460631
07/01/13 12:11 AM
07/01/13 12:11 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Re: Bead Blaster Window Protector? [Re: mopars4ever] #1460632
07/01/13 01:20 AM
07/01/13 01:20 AM
Spokane Valley, WA
Spokane Valley, WA
Four sheets for $10 plus shipping... Not terrible, but I need it now and seems like I could buy a whole role for $15...
I’m listening.
Re: Bead Blaster Window Protector? [Re: Big Bad Bee] #1460633
07/01/13 02:39 AM
07/01/13 02:39 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use clear box tape works great
Re: Bead Blaster Window Protector? [Re: Big Bad Bee] #1460634
07/01/13 07:55 AM
07/01/13 07:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I cover the whole window with duct tape and only remove what I need to see. After a while the whole window needs replaced. I don't use a HF blaster, I got mine locally here in town and they sell all the acc/glass and have them in stock.
Re: Bead Blaster Window Protector? [Re: Challenger 1] #1460635
07/01/13 08:35 AM
07/01/13 08:35 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Pick up some clear mylar sheets at a local stationary, craft, or hobby store and use double back tape to secure it to the underside of the glass.
Re: Bead Blaster Window Protector? [Re: Pntastar69] #1460636
07/01/13 09:17 AM
07/01/13 09:17 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Find a distributor of "plastic sheet, rod and tube" in your local Yellow Pages. Ask for a sheet of PETG. .020 works well and cuts with a utility knife. Here in Canada a 4' x 8' sheet sells for $30. and you can probably get 16 pieces out of it. You can get thinner or thicker.
Re: Bead Blaster Window Protector? [Re: Stanton] #1460637
07/01/13 10:23 AM
07/01/13 10:23 AM
I ain't in that position but what Challenger & BulletBob said makes good sense: covering most of the screen leaving just enough to see what you're doing then some clear packaging tape: cheap/practical/simple
Re: Bead Blaster Window Protector? [Re: RapidRobert] #1460638
07/01/13 10:55 AM
07/01/13 10:55 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And a mess to remove !! Go to any hardware store,most have clear roll vinyl (same thing you use for storm windows) anywhere from 4 to 12 mill,52" wide usually around $3.00 /$3.50 a yard.
Re: Bead Blaster Window Protector? [Re: 62maxwgn] #1460639
07/01/13 11:28 AM
07/01/13 11:28 AM
Cincinnati, Ohio
Cincinnati, Ohio
The problem with a sheet of plastic is the media still get's in between it and the glass and you can't see and then the whole sheet of plastic get's blurred and then the whole thing needs to be replaced too often.
The least of the PIA is to tape up the window and remove what you need to see with a razor blade scraper. Then you have a nice little 3X3" window that is new to see through each time you remove a section of tape. Like I said eventually you will need new glass no matter how you do it. This method was suggested to me by the guys who sell the equipment and is the least PIA, I have been using my blast cabinet for over 25 years now.
Re: Bead Blaster Window Protector? [Re: Challenger 1] #1460640
07/01/13 11:39 AM
07/01/13 11:39 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
Not if you double back tape it to the underside of the glass, as I mentioned earlier.
Re: Bead Blaster Window Protector? [Re: Pntastar69] #1460641
07/01/13 12:03 PM
07/01/13 12:03 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I use the plastic film over the glass and tape all the way around. Never any media between the glass and this will last 8-10 hrs of blast time if your paying attention. Changing the film takes only a couple minutes and I have a nice large 12"X24" window to look through. This cabinet sees 20-25 hrs of blast time per week.
Re: Bead Blaster Window Protector? [Re: 64dodge572] #1460642
07/01/13 03:29 PM
07/01/13 03:29 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Graingers sells big rolls of the right stuff.
Re: Bead Blaster Window Protector? [Re: 4406bbl] #1460643
07/01/13 04:01 PM
07/01/13 04:01 PM
Spokane Valley, WA
Spokane Valley, WA
Great responses, guys! Thank you!
I’m listening.
Re: Bead Blaster Window Protector? [Re: Big Bad Bee] #1460644
07/01/13 09:05 PM
07/01/13 09:05 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I spend the $6 for a new window from the glass shop every year or so. I also installed rivnuts to hold the frame instead of using screws and nuts...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Bead Blaster Window Protector? [Re: astjp2] #1460645
07/01/13 09:40 PM
07/01/13 09:40 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Re: Bead Blaster Window Protector? [Re: 62maxwgn] #1460646
07/02/13 12:50 AM
07/02/13 12:50 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
And a mess to remove !! Go to any hardware store,most have clear roll vinyl (same thing you use for storm windows) anywhere from 4 to 12 mill,52" wide usually around $3.00 /$3.50 a yard. [/quote
Peels right off not a mess to remove.
Been doing it that way for 25+years
Of course it gets used almost every day that might count.
I will tell you one thing though we've put more expanded metal & gloves on it than glass over the years
It pays to think with your mind & money
I buy 3M tape & don't scrape anything
Re: Bead Blaster Window Protector? [Re: astjp2] #1460647
07/02/13 11:10 AM
07/02/13 11:10 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
