2001 Jeep GC 4.0 4x4 auto trans replacement?? #1460570
06/30/13 11:11 PM
06/30/13 11:11 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Guys,
How hateful is it to replace a auto trans on a GC without a lift? Would it be better to pull the engine and the trans together from under the hood? Or tell my girlfriend to have someone do it that has access to a lift?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement?? [Re: GO_Fish] #1460571
07/01/13 09:20 PM
07/01/13 09:20 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I told her today to find a mechanic with a lift to swap the trans. I'm getting too old (and lazy?) to try and squeeze under there with jack stands and wrestle that thing in and out. Don't need to wreck my back before vacation either.
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement?? [Re: GO_Fish] #1460572
07/02/13 02:34 PM
07/02/13 02:34 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Plenty of room to work,at age 60 I won't do it.The wiring harness that goes to the trans is to short,have whoever does the work extend it or it will never reconnect to the trans firmly and repeatedly leave her stranded.Ask my wife how I know.
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement?? [Re: Geezer] #1460573
07/02/13 07:58 PM
07/02/13 07:58 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I ran a trans shop up until 2010 and never had to extend a harness on one
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement?? [Re: dusturbd340W5] #1460574
07/03/13 02:31 PM
07/03/13 02:31 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Jeep dealers around here keep these in stock. http://www.electricaladvantage.net/reexternalwireharnessrepairkit.aspx
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement?? [Re: dusturbd340W5] #1460575
07/03/13 11:12 PM
07/03/13 11:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've never had to "extend" that harness, but I've replaced a ton of them. Seals in the valve body side of the connector start leaking over time, turns those wires to mush and they end up shorting together.
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement?? [Re: J_BODY] #1460576
07/03/13 11:44 PM
07/03/13 11:44 PM
Kissimmee Fl.
Kissimmee Fl.
yes I have repaired the harness but never had to make 1 longer for any reason
