Catalatic convertor in a 2003 Dodge #1460347
06/30/13 02:53 PM
06/30/13 02:53 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Hello,
My check engine light is flashing which according to the owners manual says it's the catalatic convertor. It's a 2003 Dodge with a 5.7 Hemi. I don't have to worry about emmissions and cash is really short. Will it still run right if I knock a hole in it clean it out and cover the hole back up?
Re: Catalatic convertor in a 2003 Dodge [Re: flatiron] #1460348
06/30/13 03:19 PM
06/30/13 03:19 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
A flashing check engine light means you have a cylinder misfire. A cylinder misfire will damage the catalytic converter. First thing to do is find out what cylinder is misfiring and why. How does it run?
Re: Catalatic convertor in a 2003 Dodge [Re: mod381] #1460349
06/30/13 03:28 PM
06/30/13 03:28 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Running fine no misfires and seems to pull fine when I step on the gas. I did notice the check engine light does not flash if im coasting. It only flashes when I'm pushing the gas pedal.
Re: Catalatic convertor in a 2003 Dodge [Re: flatiron] #1460350
06/30/13 03:31 PM
06/30/13 03:31 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
guess I should say it doesnt feel like it's miss firing. you know jerky feeling or popping or anything like that...But I could be wrong
Re: Catalatic convertor in a 2003 Dodge [Re: flatiron] #1460351
07/02/13 08:46 AM
07/02/13 08:46 AM
pennsylvania
poboyengineering Offline
pennsylvania
a flashing check engine light means "catalyst damaging misfire!" there is raw gas going into the cat. get it on a scanner asap, and fix the misfire. then run a cat check (drive cycle, and look at the cat flag in I/M readiness screen). if it passes, you got lucky!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
