dakota #1460317
06/30/13 01:29 PM
06/30/13 01:29 PM
ny
gkurschner Offline OP
ny
Can anyone tell me the best and most economical way to change my 6 lug 1997 Dakota 2wd to a 5 bolt pattern configuration. Any help would be appreciated. Mopar 1953
Re: dakota, pattern change [Re: gkurschner] #1460318
06/30/13 09:50 PM
06/30/13 09:50 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Starting at the rear, you would push out the studs, plug weld the axle flanges, redrill the pattern and get some matching drums. Of course, you might find that a different year 5 lug axle shaft would interchange and then you would have a new stock axle shaft. In the front you would need to go from the spindles out. In other words, research when the change was made to 5 lug, compare the spindles from yours to the 5 lug, if the spindles are the same then get new 5 lug rotors (common wear items) along with matching bearings and brakes. You can learn a lot by going to the rockauto.com web site and comparing part numbers. I was once offered a complete set of Hollander interchange manuals, I wish that I had bought them. Finally, I don't believe in wheel adapters (dangerous)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: dakota [Re: gkurschner] #1460319
07/01/13 02:56 AM
07/01/13 02:56 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Put a 90 frame under it. 90 was the last year for the 5 lug wheels.
I believe you will find not much will match up, 97 is the next generation frame (96 was the end of the old one). You have the slip on rotors, and I think the spindles are different then the old ones. I believe I've read the rear axles are different lengths then the 96 & older ones as well. Gene
Re: dakota [Re: poorboy] #1460320
07/01/13 08:55 AM
07/01/13 08:55 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Call Brandon Burns, the guy who started this thread:
http://www.dakotart.com/forum/showthread.php?t=17734
He CNC cuts his own billet hubs and then drills them to whatever bolt pattern you want.
I think he was charging around $300 shipped for the pair of front hubs
then call Moser and order yourself a set of rear axle shafts, also drilled in whatever bolt pattern you want. Cost for those was around $350 last I checked.
in the end, you get a real, "correct" 5-lug conversion for less than $700, and your aftermarket/custom wheel selection opens up, AND they are cheaper.
Or you can do the fill/drill on your original hubs/axle shafts for a lot less, and hope the welder didn't have an off day.
**Photobucket sucks**
