Squeeky S-Belt #1460278
06/30/13 01:12 PM
06/30/13 01:12 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
what is good for quieting down a noisey S-Belt? I was told normal belt dressing is a no-no...
Coming soon!!!!
Re: Squeeky S-Belt [Re: Mr.Yuck] #1460279
06/30/13 01:39 PM
06/30/13 01:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It seems like the quality of serp belts have been getting worse lately. The aftermarket belts seem to be the worse offenders.They only last about 15k anymore, the factory belts go about 30k.At the Toyota shop new Tundra belts only go about 30k before you have to replace the $150.00 belt.
Gus
64 Plymouth Savoy
Dana 60
Re: Squeeky S-Belt [Re: Mr.Yuck] #1460280
06/30/13 04:56 PM
06/30/13 04:56 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Goodyear "Gatorback" worked for me.
Re: Squeeky S-Belt [Re: Mr.Yuck] #1460281
06/30/13 04:57 PM
06/30/13 04:57 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Re: Squeeky S-Belt [Re: pushbutton] #1460282
06/30/13 05:01 PM
06/30/13 05:01 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
We use gatorbacks most of the time with no issues.
Re: Squeeky S-Belt [Re: MPerry] #1460283
06/30/13 05:37 PM
06/30/13 05:37 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ya the gater-back is very good...
Re: Squeeky S-Belt [Re: Dakota_Don] #1460284
06/30/13 06:04 PM
06/30/13 06:04 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Of course, a worn out or poor quality tensioner can make an otherwise good belt squeak.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Squeeky S-Belt [Re: wingman] #1460285
07/01/13 08:11 AM
07/01/13 08:11 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks I'll try the gator back and check the tenisoner... it quiets down after 5-10 minutes of driving.
Re: Squeeky S-Belt [Re: Mr.Yuck] #1460286
07/01/13 08:20 AM
07/01/13 08:20 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
My original Dakota serpentine belt squealed a lot. Put a new Gates on and it did the same thing. Shut the engine off and rubbed baby powder on both sides of it, didn't squeak again for quite a while.
Re: Squeeky S-Belt [Re: Mr.Yuck] #1460287
07/01/13 09:15 AM
07/01/13 09:15 AM
Tennessee
meep_meep Offline
meep_meep  Offline
Tennessee
I've always had problems with the cheapy belts, they squeak and stretch out quickly...Spend the $$ on the good belt(dayco/gatorback), don't buy the cheapy in house brand...
Re: Squeeky S-Belt [Re: meep_meep] #1460288
07/01/13 01:02 PM
07/01/13 01:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Replacing the tensioner will probably be what is needed. I went with changing to differenet brands belts etc. and the end result was I needed a new tensioner.
Re: Squeeky S-Belt [Re: mopars4ever] #1460289
07/01/13 03:14 PM
07/01/13 03:14 PM
My hovercraft is full of eels
DaveKanofsky Offline
Before installing your new belt, be sure nothing is glazed over. Rub all of the pulleys with Scotch Brite and brake cleaner first.
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: Squeeky S-Belt [Re: DaveKanofsky] #1460290
07/01/13 03:23 PM
07/01/13 03:23 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
this is on a car I picked up as a driver. I'm assuming the belt was replaced w/ the water pump a few months ago... can I spray brake clean on it while it's running?
Re: Squeeky S-Belt [Re: Mr.Yuck] #1460291
07/01/13 07:52 PM
07/01/13 07:52 PM
IN
ahy Offline
ahy  Offline
IN
Brakeclean may soften it and get it to stop for a few minutes... then its likely to let go. I don't think brakecleen and rubber get along very well. If you need something quick, belt dressing may be worth a try but the high quality belt is the best fix.
Also check the tensioner and all accessories. My daughter's Jeep tended to squeak when cold. Good belt and good tension. Finally the alternator seized up completely and completely cooked the belt. New alternator and no squeak at all. The alternator must have been tight for quite a while.
