Summit Universal Radiators #146008
11/05/08 12:46 PM
11/05/08 12:46 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
How's have you guys mounted the bottom of your universal radiators? Does anyone have any pictures? Should you sandwich some rubber or poly in between, or can it be solidly mounted?
Re: Summit Universal Radiators [Re: mopowers] #146009
11/05/08 01:24 PM
11/05/08 01:24 PM
places
79powerwagon Offline
places
Mine
Re: Summit Universal Radiators [Re: mopowers] #146010
11/05/08 03:21 PM
11/05/08 03:21 PM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
I have the exact same radiator (or the 31"-wide version). But I can't weld aluminum.
So what I did was build a rail (with a 30" piece of U-shaped aluminum) that fits inside the U-shaped underside of the rad. That rail bolts to the lower rad support with 2 L-shaped brackets. Felt liner alonside the rail.
Two aluminum brackets riveted on top of the radiator bolt through the upper rad support (in existing holes). I had to add a small piece of tubing as a filler between the top of the rad and the upper rad support (to prevent air to flow around the rad there), so the two brackets are riveted to that filler, whish is itself riveted to the rad core's top.
Here's a pic of the rail :
Re: Summit Universal Radiators [Re: fbernard] #146011
11/05/08 03:24 PM
11/05/08 03:24 PM
fbernard Offline
fbernard  Offline
Second pic, the radiator in place (it's mostly held in by the inner fender flanges that I had to grind to make the 31" radiator fit) :
Re: Summit Universal Radiators [Re: fbernard] #146012
11/05/08 03:26 PM
11/05/08 03:26 PM
fbernard Offline
fbernard  Offline
Third, the upper brackets (circled in yellow). I know the red wires look ugly, but they've since been recovered in black.
Re: Summit Universal Radiators [Re: fbernard] #146013
11/05/08 04:38 PM
11/05/08 04:38 PM
places
places
I can't weld either. But a guy near me can, and it cost me all of $50.00 to weld the mounting tabs on the radiator AND repair a cracked 727 case, machining and all!
Re: Summit Universal Radiators [Re: 79powerwagon] #146014
11/05/08 05:37 PM
11/05/08 05:37 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
This is a afco instructions said to mount by the tanks with rubber or weatherstrip lined brackets. I used some late model GM radiator rubber mount pieces trimed a bit and attached to some homemade metal brackets.
Re: Summit Universal Radiators [Re: Y3 70 BEE] #146015
11/05/08 05:39 PM
11/05/08 05:39 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
No bottom pics but the same set up .
Re: Summit Universal Radiators [Re: Y3 70 BEE] #146016
11/05/08 05:41 PM
11/05/08 05:41 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
I dont run a shroud but has not been a problem.
Re: Summit Universal Radiators [Re: Y3 70 BEE] #146017
11/05/08 06:48 PM
11/05/08 06:48 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have "be-cool" brackets for a 22" support that i bought from summit. local metal shop tigged them to the radiator, rounded the corners, and added a drain to the bottom of the tank.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Summit Universal Radiators [Re: GoodysGotaCuda] #146018
11/05/08 07:11 PM
11/05/08 07:11 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I spent a couple of bucks and bout their universal mounting kit. The tops are GM style so they got tossed, but the bottoms are J-brackets which work great. Came with that one-sticky-sided foam insulating strip that I stuck on, then bolted them to the car and slide the radiator into it. Could make similar J-brackets out of aluminum stock.
Ride eternal, shiny and chrome
Re: Summit Universal Radiators [Re: mopowers] #146019
11/05/08 09:09 PM
11/05/08 09:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Did you already buy it? I bought a aluminum 26" on e-bay that has factory mounting tabs and shrod placement for $189. It fits very well. I will be adding some rubber under it when the engine goes in. It also has factory in and outlets and trans line placement
Re: Summit Universal Radiators [Re: Mr.Yuck] #146020
11/05/08 10:14 PM
11/05/08 10:14 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Do you have a link to the one you snagged ??? thanks
Re: Summit Universal Radiators [Re: DirectSubjection] #146021
11/05/08 10:21 PM
11/05/08 10:21 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Did you put the J brackets under the tanks, or under the core?
Re: Summit Universal Radiators [Re: mopowers] #146022
11/05/08 11:08 PM
11/05/08 11:08 PM
Here
Here
Tanks - the core is completely exposed by the radiator supports original opening in my case. It slipped in nice and tight. The black strip between the radiator and support in this pic is the long side, mounted to one of the factory bolt holes...
Re: Summit Universal Radiators [Re: DirectSubjection] #146023
11/06/08 11:56 AM
11/06/08 11:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Go in the archives under no weld raditor mounts posted by me. I don't know how to pull it up and post here. There are good pictures of simple,clean mounts.
Doug
Re: Summit Universal Radiators [Re: dvw] #146024
11/06/08 01:07 PM
11/06/08 01:07 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
https://board.moparts.org/ubbthreads/show...rue#Post4409252
You should save this for the next time someone asks
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Summit Universal Radiators [Re: screamindriver] #146025
11/06/08 01:22 PM
11/06/08 01:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Actually I won it at 170! Here's his store
http://stores.ebay.com/OSCARS-RADIATORS_...52BSI%26otn%3D4
Re: Summit Universal Radiators [Re: mopowers] #146026
11/06/08 01:26 PM
11/06/08 01:26 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I found that there are some Ford brackets with rubber inserts that work well. I did some modifications to them. I used the same brackets shown here on the top, but actualy welded to the lower rad support.
Re: Summit Universal Radiators [Re: Jim_Lusk] #146027
11/06/08 02:14 PM
11/06/08 02:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Since the rest of my car basically looks like poop I didn't spend a ton of time trying to make mine look pretty, however I did make it functional with a little bracket holding a couple relays for the fan, but again nothing fancy.
I don't use that fan setup anymore though...
Rich H.
Esse Quam Videri
