Re: a couple smallblock questions.
[Re: WHITEDART]
#1460039
06/30/13 04:48 AM
06/30/13 04:48 AM
Posts: 1,019 Finland
mafo
Finland
If everything else is in order ,Fel Pro 1008 can handle a lot of pressure, my w2 engine had over 15-1 and no head gasket problems
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: 1Fast340]
#1460042
06/30/13 04:23 PM
06/30/13 04:23 PM
Posts: 7,506 Az
Crizila
Az
Ya, the longer you can keep the guides the better. A moc-up will tell you what you have to do. Just remember to include the seals in your measurements. I shoot for a minimum of .040 clearance - retainer to seal.
Fastest 300
[Re: 1Fast340]
#1460044
07/01/13 07:22 PM
07/01/13 07:22 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have the same lifters and my cam is .704 lift before the lash and I have had no issues.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1460045
07/02/13 03:27 PM
07/02/13 03:27 PM
Posts: 2,578 sweden
1Fast340
sweden
did you have to run a smaller base cam? or did you tube the oilgalery? thats some serious lift!
[Re: 1Fast340]
#1460046
07/02/13 06:58 PM
07/02/13 06:58 PM
D-50
North, Alabama
I should have been more specific. The cam has .427 lobe lift and the lifters bores are bushed.The reason it has so much lift is I have 1.65 ratio T&D rockers. I ran them in another motor without bushed lifter bores but had another cam from Bullet that had a smaller base circle. It was .665 lift.
[Re: D-50]
#1460047
07/03/13 01:16 PM
07/03/13 01:16 PM
Posts: 2,578 sweden
1Fast340
sweden
i suspected something along those lines. Thanks i appreciate any info i can get
