Walk me through my wheel and caliper installation #1459763
06/28/13 10:57 PM
06/28/13 10:57 PM
Tacoma, Washington USA
Adam71Charger Offline OP
This setup is all new to me, and Im lost. Trying to install my rotor and caliper. I have slider type calipers. Now that my 11.75 rotor wheel bearing races are installed, Im ready to put the bearings in and then onto the spindle. But, I cant figure out which way my oil seal is supposed to be facing, some directions I found say point the lip of the seal inwards, but I dont know which side is the lip or what direction inwards means.
here is the back of my rotor:
Now which way does the oil seal go into the rotor? pic 1 or pic 2??
Pic #1
Pic #2
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459764
06/28/13 11:05 PM
06/28/13 11:05 PM
S.E. WI
RichL1967 Offline
RichL1967  Offline
S.E. WI
All the seals like that I have seen were installed like #1.
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459765
06/28/13 11:08 PM
06/28/13 11:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pic 2 goes to the outside.Pic one goes to the bearing side.A lot of the new seal dont have the rubber piece.Rocky
Chrysler Firepower
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459766
06/28/13 11:12 PM
06/28/13 11:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sharp edge of the seals lip goes into rotor to keep the grease in. Sharp edge of the seal always goes to the source of the fluid to keep it in rather than channeling it out. The lip allows the fluid or grease to be moved away from the shaft or in this case the spindle instead of forcing it by the seal.
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459767
06/28/13 11:12 PM
06/28/13 11:12 PM
Shoreline, Washington
72roadrunnergtx Offline
#2 is the correct way to install that seal.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Walk me through my wheel and caliper installation [Re: RichL1967] #1459768
06/28/13 11:15 PM
06/28/13 11:15 PM
ok, got it in. Now, the shop manual says to put on the rotor and bearings, then the thrust washer and adjusting nut, then tighten the adjusting nut to 90 ft/lbs, then back off enought to fit cotter pin in. The end result should be zero to .003" end play.
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459769
06/28/13 11:19 PM
06/28/13 11:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you pack the bearings?
Re: Walk me through my wheel and caliper installation [Re: stumpy] #1459770
06/28/13 11:25 PM
06/28/13 11:25 PM
yes I packed the bearings. Then i tightened the adjustment nut to 90lbs, and backed off just a little.. the rotor is difficult to turn, doesnt feel right
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459771
06/28/13 11:36 PM
06/28/13 11:36 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Probally too tight.I alwyas tighten them tight then back off till just loose.Then just snug them down.Ive done them for over 40 years but once you do them a few times you get the feel for it.I dont like tight bearings.As long as the rotor dosent move they are good.Some drag will be felt.Try loosening them.Till loose and turn the rotor.Then start snugging till you fell a bit of drag spinning the rotor.Then install the cotter key.I did them at work for over 30 years and never had a bearing failure.Rocky
Chrysler Firepower
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459772
06/28/13 11:37 PM
06/28/13 11:37 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
new bearings and grease are hard to turn, u will find it easier to turn once you mount the wheel assy...try it..mount it on with lug nuts..and spin
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459773
06/28/13 11:40 PM
06/28/13 11:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not a factory shop manual is it?
Should be 90 INCH/pounds, typo in the manual. Ran into that one a long time ago.
Don't be the exception.
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459774
06/28/13 11:45 PM
06/28/13 11:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yeah, 90 foot pounds is way too tight and pic #1 is WRONG.
Re: Walk me through my wheel and caliper installation [Re: buildanother] #1459775
06/29/13 12:19 AM
06/29/13 12:19 AM
90...inch..lbs...my bad
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459776
06/29/13 01:23 AM
06/29/13 01:23 AM
so this is one of my caliper sets, it says L so Im assuming it's drivers side. Do I use all of these pieces? or are they just there as a universal setup for multiple applications?
Here's all the pieces.
I put 1 pad on first, it hangs itself on the grooves of the caliper adapter, then on goes the other pad and caliper body. The outlet for the brake hose is pointing towards the rear of the car, this seems correct.. or do I have the calipers switched?
Then I attached the 2 larger metal plates and bolts, although I dont know which way they are supposed to face
Now I have these pieces left over. what are they for?
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459777
06/29/13 01:26 AM
06/29/13 01:26 AM
Central TX
roe Offline
roe  Offline
Central TX
Did mine a while back and instAlled like pic#2. That was based off my Manual and the old ones that I pulled off.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Walk me through my wheel and caliper installation [Re: roe] #1459778
06/29/13 01:38 AM
06/29/13 01:38 AM
dogdays Offline
dogdays  Offline
One universal truth is that the bleeder screw should be on the top of the caliper.
R.
Re: Walk me through my wheel and caliper installation [Re: dogdays] #1459779
06/29/13 02:05 AM
06/29/13 02:05 AM
put the 2 small tin pieces on the bolt(s) then the bolt/tin piece goes in/thru the large tin pieces, in other words the bolt goes thru the small tin piece then thru the large flat tin piece. Want the 1 pad to be loose as installed & file the ends if need be. The other pad with the 2 "L" mounting tabs you want to bend them (the L tabs) so you have to hammer tap that pad half in place so the pad is firmly secured to the caliper. Put disc brake quiet on the back side of the pads where there is contact. Clean the rotor/front pad faces with brake kleen. The "L" is referring to the left caliper which are side specific not the parts in the pic. FYI 76 A body calipers & FMJ calipers have a 2.75" bore & 73-75 A body calipers have 2.60" bore & you want the largest bore on the front you can get. Toss the rubber bands.
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459780
06/29/13 02:08 AM
06/29/13 02:08 AM
Calgary, Alberta Canada
a12rag Online content
a12rag  Online Content
Those two pieces go under the bolt (top & bottom) of the caliper - where you put the metal pieces. These are the anti rattle pieces that go over the brake pad "ears" . . sorry, don't have a pic . . am sure someone will post a pic . . . oh, and the "elastic" band parts - supposed to go on the caliper adapter, where the pad ears sit, kinda like anti rust/sieze item - but they always get chewed up and are never there, don't worry about NOT putting them on !
Cheers
Mark
Re: Walk me through my wheel and caliper installation [Re: RapidRobert] #1459781
06/29/13 03:12 AM
06/29/13 03:12 AM
put the 2 small tin pieces on the bolt(s) then the bolt/tin piece goes in/thru the large tin pieces, in other words the bolt goes thru the small tin piece then thru the large flat tin piece. Want the 1 pad to be loose as installed & file the ends if need be. The other pad with the 2 "L" mounting tabs you want to bend them (the L tabs) so you have to hammer tap that pad half in place so the pad is firmly secured to the caliper. Put disc brake quiet on the back side of the pads where there is contact. Clean the rotor/front pad faces with brake kleen. The "L" is referring to the caliper(s) which are side specific not the parts in the pic. FYI 76 A body calipers & FMJ calipers have a 2.75" bore & 73-75 A body calipers have 2.60" bore & you want the largest bore on the front you can get. Toss the rubber bands.
Ill try this tomorrow.
and I got calipers for a 77 Diplomat so I got the 2.75"
Re: Walk me through my wheel and caliper installation [Re: Adam71Charger] #1459782
06/29/13 08:15 AM
06/29/13 08:15 AM
BDW Online content
BDW  Online Content
O-rings go here
