pt cruiser replacement headlights any good? #1459645
06/28/13 06:30 PM
06/28/13 06:30 PM
central P.A.
HEMIDOG 70 Offline OP
central P.A.
I need to replace the headlight assemblies on my daughters 01 pt. They are yellowed beyond the point of polishing. Has anyone used these aftermarket replacements? Do they fit? will the plastic hold up? and lastly how hard are the assemblies to change?
http://www.ebay.com/itm/01-05-CHRYSLER-P...a2a&vxp=mtr
Re: pt cruiser replacement headlights any good? [Re: HEMIDOG 70] #1459646
06/28/13 06:37 PM
06/28/13 06:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
All the after market ones on ebay are Kun Fu and what I found was they leak water and the bulbs aren't very bright. Some of the parts store ones are made in south of the border and might be a little better.I put Kun Fu ones in my Neon, they leak and fit so, so, in fact one has green stuff growing in it. Best thing is to drill a small hole so any water can evaporate. Also I put the best Silvana bulbs in and what a difference they make. Its almost like having a 4 lamp set up. I can see again.
Re: pt cruiser replacement headlights any good? [Re: 71birdJ68] #1459647
06/28/13 06:42 PM
06/28/13 06:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Nothing on a cruiser is easy. Have you tried the Mothers kit with the sanding pads and polish. It worked well on both my Cruisers?
http://www.ehow.co.uk/how_6567882_remove-headlight-assembly-pt-cruiser.html
Re: pt cruiser replacement headlights any good? [Re: HEMIDOG 70] #1459648
06/28/13 06:54 PM
06/28/13 06:54 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I got a set off EBag for my 02 Ram. They were excellent quality and fit perfect.They were from Vision Technology.
Nautilus Racing-
Re: pt cruiser replacement headlights any good? [Re: HEMIDOG 70] #1459649
06/28/13 08:21 PM
06/28/13 08:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Bought one side for the 04 Ram.Fit was good and looks like the OE one.The bulbs as said arent as bright.No leaks and its been in almost 2 years.I need to polish or replace the one side on the wifes 03 PT.Rocky
Chrysler Firepower
