Oil pump drive clearance,shaft to bushing #1459265
06/28/13 12:48 AM
06/28/13 12:48 AM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
In an ideal world,how tight are these?Going to try and fix this one here (see other post)in the car,pioneer supposed to compress the right amount upon install, but we will be checking carefully.
Do you all use a cam button of any sort to help the BB stop the fore and aft motion?Chain looks and feels like new, so back it goes.
Thanks,
Bear
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459266
06/28/13 02:32 AM
06/28/13 02:32 AM
You want it to where the shaft just turns nice & free in the bushing. I've never used a cam button in the front & dont know if it's needed just with roller lifters or not. I figure the normal rotation pushes the cam rearward (on a BB). Here's a BTT for ya Bear
Re: Oil pump drive clearance,shaft to bushing [Re: RapidRobert] #1459267
06/28/13 04:26 AM
06/28/13 04:26 AM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Thanks, Rapid-O!
Good to have you weigh in,been missing your sage advice!
#1 cam bearing looks a little sketchy, may be changing that one alone (HaHa)
We shall see when the new bushing arrives from Whamazon,a little over 4 bucks for the part, 8 bucks for freight.So much for the land of palm trees and hula girls...:-)
Still would like a clearance # in thousandths to satisfy my telescope machinist Mr.Evans who was brought in as insultant.(Amazing what 2 shots of tekillya will get you...)
Thanks,
Bear
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459268
06/28/13 09:27 AM
06/28/13 09:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Actually there is a reamer to size them.Like said it should slide in easy and spin freely without slop.As for a cam button no way.Only with a roller or gear drive.The oil pump drive keeps the cam in place.Cam bearings unless really bad leave them alone.The ones my kids truck had looked terrible.But the journals on the cam and oil pressure were perfect.Rocky
Chrysler Firepower
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459269
06/28/13 09:45 AM
06/28/13 09:45 AM
So much for the land of palm trees and hula girls...:-):
& you're still moving to Washington (state) right?
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459270
06/28/13 10:15 AM
06/28/13 10:15 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Bear, flat tappet cam no button .
Re: Oil pump drive clearance,shaft to bushing [Re: JohnRR] #1459271
06/28/13 12:42 PM
06/28/13 12:42 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Drive Bushing Bore (after install) .4865"-.4880"
Shaft to Bushing Clearance .0007"-.0027"
2011 Drag Pak Challenger
Re: Oil pump drive clearance,shaft to bushing [Re: rickseeman] #1459272
06/28/13 02:18 PM
06/28/13 02:18 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Rapid,yes I am still trying, throwing stuff away, giving stuff away,cleaning up,sending applications out, and fixing all the blown up crud that keeps breaking :-)
John, Rocky,thanks for the definitive answer.No button.Good.
rickseeman thank you for the magic numbers, they will go in the book here next to last nights snap gauge measurements
(so let it be written, so let it be done)
Forward, men! Have a great friday, the weekend is upon us!
Regards, Greasy Bear
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459273
06/28/13 05:51 PM
06/28/13 05:51 PM
I use a stock BB oil pump drive to install the new bushings, I put the new bushing on the shaft up near the gear with a little oil inside the bushing to hold it onto the shaft and put both of them in the block, get the bushing square to the hole( look through the slot behind and above the cam gear and use a long brass drift or something else soft like a wooden hammer handle to drive the gear with the bushing into the hole Works good, last a long time I also use a small mill file to file a small groove across the tops of the Pioneer bushings, if they don't have them already . The stock Mopar ones have a groove across both sides around .045 wide and similar depth to oil the top of the bushing and the bottom of the gear
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459274
06/28/13 10:18 PM
06/28/13 10:18 PM
(more) experienced travelers know to always travel as light as possible. You can drop off those 'source heads at my place on your way there
Re: Oil pump drive clearance,shaft to bushing [Re: RapidRobert] #1459275
06/28/13 10:47 PM
06/28/13 10:47 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
bring those goodies here. no shipping costs to anywhere else....
I am truckless..
Re: Oil pump drive clearance,shaft to bushing [Re: 340SHORTY] #1459276
06/28/13 11:41 PM
06/28/13 11:41 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
This IS true, Larry...I am coming your way , that would be convenient, could just throw them out the window of the rent a wreck as I pass by on the way to the poo plant
or maybe send one to Rapid,and bring one to you, and you guys could combine forces like Shazam or the power twins or something
That's one of the benefits of getting up there I am really looking forward to, more like-minded lunatics!
Bear
Re: Oil pump drive clearance,shaft to bushing [Re: Sixgun] #1459277
06/29/13 02:07 AM
06/29/13 02:07 AM
That's one of the benefits of getting up there I am really looking forward to, more like-minded lunatics! Bear
Be carefull what you wish for
