Oil pump drive clearance,shaft to bushing
#1459265
06/28/13 12:48 AM
06/28/13 12:48 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
In an ideal world,how tight are these?Going to try and fix this one here (see other post)in the car,pioneer supposed to compress the right amount upon install, but we will be checking carefully. Do you all use a cam button of any sort to help the BB stop the fore and aft motion?Chain looks and feels like new, so back it goes. Thanks, Bear
Re: Oil pump drive clearance,shaft to bushing
[Re: Sixgun]
#1459266
06/28/13 02:32 AM
06/28/13 02:32 AM
RapidRobert
You want it to where the shaft just turns nice & free in the bushing. I've never used a cam button in the front & dont know if it's needed just with roller lifters or not. I figure the normal rotation pushes the cam rearward (on a BB). Here's a BTT for ya Bear
[Re: RapidRobert]
#1459267
06/28/13 04:26 AM
06/28/13 04:26 AM
Sixgun
Western Washington
Thanks, Rapid-O! Good to have you weigh in,been missing your sage advice! #1 cam bearing looks a little sketchy, may be changing that one alone (HaHa) We shall see when the new bushing arrives from Whamazon,a little over 4 bucks for the part, 8 bucks for freight.So much for the land of palm trees and hula girls...:-) Still would like a clearance # in thousandths to satisfy my telescope machinist Mr.Evans who was brought in as insultant.(Amazing what 2 shots of tekillya will get you...) Thanks, Bear
[Re: Sixgun]
#1459268
06/28/13 09:27 AM
06/28/13 09:27 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Actually there is a reamer to size them.Like said it should slide in easy and spin freely without slop.As for a cam button no way.Only with a roller or gear drive.The oil pump drive keeps the cam in place.Cam bearings unless really bad leave them alone.The ones my kids truck had looked terrible.But the journals on the cam and oil pressure were perfect.Rocky
Chrysler Firepower
[Re: JohnRR]
#1459271
06/28/13 12:42 PM
06/28/13 12:42 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Drive Bushing Bore (after install) .4865"-.4880" Shaft to Bushing Clearance .0007"-.0027"
2011 Drag Pak Challenger
[Re: rickseeman]
#1459272
06/28/13 02:18 PM
06/28/13 02:18 PM
Sixgun
Western Washington
Rapid,yes I am still trying, throwing stuff away, giving stuff away,cleaning up,sending applications out, and fixing all the blown up crud that keeps breaking :-) John, Rocky,thanks for the definitive answer.No button.Good. rickseeman thank you for the magic numbers, they will go in the book here next to last nights snap gauge measurements (so let it be written, so let it be done) Forward, men! Have a great friday, the weekend is upon us! Regards, Greasy Bear
[Re: Sixgun]
#1459273
06/28/13 05:51 PM
06/28/13 05:51 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I use a stock BB oil pump drive to install the new bushings, I put the new bushing on the shaft up near the gear with a little oil inside the bushing to hold it onto the shaft and put both of them in the block, get the bushing square to the hole( look through the slot behind and above the cam gear and use a long brass drift or something else soft like a wooden hammer handle to drive the gear with the bushing into the hole Works good, last a long time I also use a small mill file to file a small groove across the tops of the Pioneer bushings, if they don't have them already . The stock Mopar ones have a groove across both sides around .045 wide and similar depth to oil the top of the bushing and the bottom of the gear
[Re: RapidRobert]
#1459275
06/28/13 10:47 PM
06/28/13 10:47 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
(more) experienced travelers know to always travel as light as possible. You can drop off those 'source heads at my place on your way there
bring those goodies here. no shipping costs to anywhere else....
I am truckless..
[Re: 340SHORTY]
#1459276
06/28/13 11:41 PM
06/28/13 11:41 PM
Sixgun
Western Washington
This IS true, Larry...I am coming your way , that would be convenient, could just throw them out the window of the rent a wreck as I pass by on the way to the poo plant or maybe send one to Rapid,and bring one to you, and you guys could combine forces like Shazam or the power twins or something That's one of the benefits of getting up there I am really looking forward to, more like-minded lunatics! Bear
