Aluminum water pump housings B/RB
#145852
11/05/08 01:01 AM
11/05/08 01:01 AM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
I've owned many a Mopar Performance aluminum water pump housing, but now I see cheaper stuff out there- CAT etc...
Are the CAT water pump housings good usable pieces? Is there others?
CrAzYMoPaRGuY
Re: Aluminum water pump housings B/RB
[Re: CrAzYMoPaRGuY]
#145853
11/05/08 01:58 AM
11/05/08 01:58 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
beats me..I realy havent looked..
mine is a Mopar aluminum housing with a CVR pump..
I sold an aluminum housing that I had on the other engine for 50 bucks...if you dont mind a good used one look around for those deals..
[Re: smokinwoody]
#145854
11/05/08 02:08 AM
11/05/08 02:08 AM
CrAzYMoPaRGuY
Canada
I just bought a brand new MoPar Performance housing, one of the heater hose holes was drilled and tapped at an angle.
Maybe the older ones had better tolerances, I don't know- but I've never had that problem before.... a little nit picky I guess.
I've never ran an "imitation" pump housing. I wonder how many there are, they are for sale all over- cheapy cheap!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#145855
11/05/08 02:14 AM
11/05/08 02:14 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
440S has one that has the inlet on the passenger side. That one is EZier to match-up to an aftermarket rad. BUTTT ...you could plumb all that hot-water from the engine AND the hot-air from the driver to that STEEL holding tank in your RV !
[Re: RUNCHARGER]
#145861
12/16/08 05:10 PM
12/16/08 05:10 PM
Posts: 216 united kingdom
Simonic
united kingdom
Has anybody got any experience of the aluminium housings available from either KMJ Performance or RacersAuctions?
Keeping the Bee Buzzin'
[Re: feets]
#145862
12/16/08 05:24 PM
12/16/08 05:24 PM
CAT?
Chinese Aluminum Trash?
#145863
12/16/08 06:31 PM
12/16/08 06:31 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
passenger side outlets are for 73 and later assemblies...nevre have seen one.
try to fit one of those aluminium housing available with outlet on driver side on to 73 and later cars, would requiere relocate the steering pump.
Does somebdoy knows about 73 and laters aluminium housings ?
[Re: NachoRT74]
#145865
12/16/08 06:37 PM
12/16/08 06:37 PM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
440 Source makes a housing with passenger side inlet for '73-up cars and for pickups. I have one in my shop right now. Nice piece! I use many of 440 Source's housings, and I have no quality issues to report at this time. Good stuff!
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: maundmotorworks]
#145866
12/16/08 07:48 PM
12/16/08 07:48 PM
Simonic
united kingdom
Just had a look at the 440 Source link. They do look to be really nice
[Re: THESHAKERPROJECT]
#145870
12/17/08 01:25 PM
12/17/08 01:25 PM
Posts: 741 Carson City, NV
440sourcedotcom
Carson City, NV
My MP alumn housing did the same thing with alum (edelbrock) pump,needed 2 gaskets to clear.
The reason people are having the "scraping" issue with ours and Edelbrocks pumps is that they require a gasket that is at least .050" thick. Many of the gaskets on the market are made of thin material (.020-.030), and that's why people need to double them up.
The closer you can get the impeller to the machined area in the housing, the more efficient the pump will be, so we all try to get it as close as possible. However, you must use the correct gasket, or it will scrape slightly. Our part number 112-1008 is a nice thick one for about 6 bucks.
