Aluminum water pump housings B/RB #145852
11/05/08 01:01 AM
11/05/08 01:01 AM
Canada
CrAzYMoPaRGuY Offline OP
Canada
I've owned many a Mopar Performance aluminum water pump housing, but now I see cheaper stuff out there- CAT etc...
Are the CAT water pump housings good usable pieces?
Is there others?
CrAzYMoPaRGuY
Re: Aluminum water pump housings B/RB [Re: CrAzYMoPaRGuY] #145853
11/05/08 01:58 AM
11/05/08 01:58 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Is there others?
beats me..I realy havent looked..
mine is a Mopar aluminum housing with a CVR pump..
I sold an aluminum housing that I had on the other engine for 50 bucks...if you dont mind a good used one look around for those deals..
Re: Aluminum water pump housings B/RB [Re: smokinwoody] #145854
11/05/08 02:08 AM
11/05/08 02:08 AM
Canada
Canada
I just bought a brand new MoPar Performance housing, one of the heater hose holes was drilled and tapped at an angle.
Maybe the older ones had better tolerances, I don't know- but I've never had that problem before.... a little nit picky I guess.
I've never ran an "imitation" pump housing. I wonder how many there are, they are for sale all over- cheapy cheap!
CrAzYMoPaRGuY
Re: Aluminum water pump housings B/RB [Re: CrAzYMoPaRGuY] #145855
11/05/08 02:14 AM
11/05/08 02:14 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
440S has one that has the inlet on the passenger side. That one is EZier to match-up to an aftermarket rad.
BUTTT ...you could plumb all that hot-water from the engine AND the hot-air from the driver to that STEEL holding tank in your RV !
Re: Aluminum water pump housings B/RB [Re: dOc !] #145856
11/05/08 09:23 AM
11/05/08 09:23 AM
Canada
Canada
They don't make a fiberglass water pump housing do they?
Now what does THAT tell you..?!?!
CrAzYMoPaRGuY
Re: Aluminum water pump housings B/RB [Re: CrAzYMoPaRGuY] #145857
11/05/08 12:11 PM
11/05/08 12:11 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
We, Hughes Engines, offer an aluminum water pump and housing(p/n 1830) that is supplied by PRW. It is an import but it fits really well and works good.
Re: Aluminum water pump housings B/RB [Re: CrAzYMoPaRGuY] #145858
11/05/08 07:33 PM
11/05/08 07:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Is there others?
CAT?
Chinese Aluminum Trash?
- Stu Harmon
Re: Aluminum water pump housings B/RB [Re: feets] #145859
11/05/08 10:19 PM
11/05/08 10:19 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
We are buying ourselves out of a job! I'm going to stop buying imports whenever I can.
Re: Aluminum water pump housings B/RB [Re: CrAzYMoPaRGuY] #145860
11/05/08 10:54 PM
11/05/08 10:54 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I used a 440 source one on my Road Runner. It was better quality than the MP piece I have on my Coronet. I don't mind paying more for N.A. stuff however I have been fleeced too many times by MP in the last 5 or more years, I cannot reward them for being screwups anymore.
Sheldon
Re: Aluminum water pump housings B/RB [Re: RUNCHARGER] #145861
12/16/08 05:10 PM
12/16/08 05:10 PM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
Has anybody got any experience of the aluminium housings available from either KMJ Performance or RacersAuctions?
Keeping the Bee Buzzin'
Re: Aluminum water pump housings B/RB [Re: feets] #145862
12/16/08 05:24 PM
12/16/08 05:24 PM
Is there others?
CAT?
Re: Aluminum water pump housings B/RB #145863
12/16/08 06:31 PM
12/16/08 06:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
passenger side outlets are for 73 and later assemblies...nevre have seen one.
try to fit one of those aluminium housing available with outlet on driver side on to 73 and later cars, would requiere relocate the steering pump.
Does somebdoy knows about 73 and laters aluminium housings ?
Re: Aluminum water pump housings B/RB [Re: NachoRT74] #145864
12/16/08 06:35 PM
12/16/08 06:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
NEVERMIND!!! GOT THE SOURCE lol
http://www.440source.com/wpumphousings.htm
Re: Aluminum water pump housings B/RB [Re: NachoRT74] #145865
12/16/08 06:37 PM
12/16/08 06:37 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
440 Source makes a housing with passenger side inlet for '73-up cars and for pickups. I have one in my shop right now. Nice piece! I use many of 440 Source's housings, and I have no quality issues to report at this time. Good stuff!
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Aluminum water pump housings B/RB [Re: maundmotorworks] #145866
12/16/08 07:48 PM
12/16/08 07:48 PM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
Just had a look at the 440 Source link.
They do look to be really nice
Re: Aluminum water pump housings B/RB [Re: CrAzYMoPaRGuY] #145867
12/16/08 08:04 PM
12/16/08 08:04 PM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
My brother is using the 440 source housing, pump and thermostat neck. The pumps impeller lightly scraped the inside of the housing without using 2 gaskets for clearance. Also the bolt spacing was different between the thermostat neck and water pump housing...the bolt holes in the thermostat housing had to be widened quite a lot to be able to bolt it to the housing. The castings all looked nice but the machining was a bit off.
Re: Aluminum water pump housings B/RB [Re: 4004spd] #145868
12/16/08 09:05 PM
12/16/08 09:05 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
My MP alumn housing did the same thing with alum (edelbrock) pump,needed 2 gaskets to clear.
Re: Aluminum water pump housings B/RB [Re: THESHAKERPROJECT] #145869
12/16/08 09:27 PM
12/16/08 09:27 PM
Missouri
NFURY8 Offline
super street
NFURY8  Offline
super street
Missouri
I have had the 440 source housing on the 440 in my Fury for a couple years now. Everything bolted on fine and it hasn't needed a thing since installed. Very happy!! Plan to use another on the 71 PowerWagon soon. I have had my fair share of MP junk also.
C-Body DryDock Bigger is Better!
Re: Aluminum water pump housings B/RB [Re: THESHAKERPROJECT] #145870
12/17/08 01:25 PM
12/17/08 01:25 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
The reason people are having the "scraping" issue with ours and Edelbrocks pumps is that they require a gasket that is at least .050" thick. Many of the gaskets on the market are made of thin material (.020-.030), and that's why people need to double them up.
The closer you can get the impeller to the machined area in the housing, the more efficient the pump will be, so we all try to get it as close as possible. However, you must use the correct gasket, or it will scrape slightly. Our part number 112-1008 is a nice thick one for about 6 bucks.
Re: Aluminum water pump housings B/RB [Re: 440sourcedotcom] #145871
12/17/08 04:44 PM
12/17/08 04:44 PM
Westphalia, Meeeeeshigan
MIRADAMANia Offline
MIRADAMANia  Offline
How about including the gasket in the package?
