where is the timing tab located on a /6 #1458048
06/25/13 01:31 PM
06/25/13 01:31 PM
Springfield Oregon
badblubeee Offline OP
super gas
super gas
Springfield Oregon
I have a '68 225 and it has no timing tab. I also have a '76 Duster with a 225-are the tabs located in the same place? If not then where?
thanks for any info
Re: where is the timing tab located on a /6 [Re: badblubeee] #1458049
06/25/13 04:03 PM
06/25/13 04:03 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Not sure about 1968 but my 1965's is located about 1 or 2 o'clock on the timing cover and is hidden by my aftermarket a/c idler pulley. I have to remove the belt and pulley to use a timing light. If yours is all stock it should be pretty easy to see,might just be covered with dirt.
Re: where is the timing tab located on a /6 [Re: badblubeee] #1458050
06/25/13 04:34 PM
06/25/13 04:34 PM
There have been several different slant six timing tabs over the years. I think this is correct: From 61 through 66 or so, there was a bolt-on tab on the driver's side lower front corner of the timing cover. Next version (67-77) had a tab welded onto the timing cover. Here's a picture of the latter I pulled off another forum:
Re: where is the timing tab located on a /6 #1458051
06/25/13 04:37 PM
06/25/13 04:37 PM
Of course, your 68 may or may not have its original 68 motor. There was also a post-77 version on the passenger side. Here's a pic of the earlier (61-66) bolt-on tab (also lifted from another forum):
Re: where is the timing tab located on a /6 #1458052
06/25/13 04:39 PM
06/25/13 04:39 PM
And finally, because the tabs were in different places, the timing marks on the crank pulley/damper are in different places to match whatever tab a particular motor had.
Re: where is the timing tab located on a /6 #1458053
06/25/13 06:21 PM
06/25/13 06:21 PM
Springfield Oregon
super gas
super gas
Springfield Oregon
Hey thaks for all the replys.The car is a '63 Valiant convert with a '68 engine so you are correct-it's not original.
It's not geasey, in fact that area of the engine is spotless and freshy painted because I just installed a new timing chain and gears. that's what got me into the whole timing thing.I had everything apart and wire wheeled everything and found no evedence of a tab ever being on the cover and none anywhere else!
Anyways I TDC'ed no 1 and got the rotoer pointed in the right direction and it fired right up I'll be crusin' topless for 4th o july!
thanks again -Dave
