shifter cable #1457854
06/25/13 02:45 AM
06/25/13 02:45 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok I asked this on the truck thread an thought maybe throwing it on here might get some hit's, ok I have a b&m quick silver shifter I will be installing in my d150, BUT I don't have the motor or tranny in yet ( still in the building stage )so I need to know what the length the cable need's to be if possible.. the rig is a 81 d150, 318/727 swap.. I bought a used shifter so it never came with the cable any info would be great
drive fast, drive hard, DRIVE MOPAR
Re: shifter cable [Re: lifted85] #1457855
06/25/13 03:05 PM
06/25/13 03:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would probally try to mock up where I would want the shifter and then use a measuring tape to find the length to a hole in the firewall to run the cable through and then measure to the trans. mounting points I would think a six foot long one may work well Make sure and keep the cable away from the headers or exhaust pipes
Re: shifter cable [Re: Cab_Burge] #1457856
06/25/13 03:08 PM
06/25/13 03:08 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
....also be sure to GROUND the engine properly through the chassis or it could find-that-ground through the cable and damage said-cable ...
Re: shifter cable [Re: Cab_Burge] #1457857
06/25/13 04:53 PM
06/25/13 04:53 PM
Make sure and keep the cable WAY away from the headers or exhaust pipes
Fixed it.
Those cables will melt if you glare at them.
Re: shifter cable [Re: lifted85] #1457858
06/25/13 05:20 PM
06/25/13 05:20 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The cable that comes with the Quicksilver is really long. I now use black Insultherm on the B&M cables but the old cheaper stuff works as well. Just make sure you use something or it will melt.
Re: shifter cable [Re: Lefty] #1457859
06/26/13 03:07 AM
06/26/13 03:07 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
hey Lefty do ya know about how long the cable was with the quick silver?? I was told 5ft should be good? but don't want to come up short but don't want to come up long.. I will be running long tube header's, dumper's probably before the box if that make's a difference, would I be better off with the 6ft?? like I have said before I KNOW NOTHING about them there auto O matic's lol..
Re: shifter cable [Re: lifted85] #1457860
06/26/13 04:08 AM
06/26/13 04:08 AM
Lefty Offline
Lefty  Offline
I suspect it will be perfect.
