Re: 727 Front Seal Replacement
[Re: 469runner]
#145746
11/04/08 10:32 PM
11/04/08 10:32 PM
Posts: 30,449 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Get a screwdriver and knock it sideways, then grab with pliers and pull out. No big deal. Drive new seal in with a mallet ot small hammer evenly. Done deal. I've been doing it this way for 30 years.
To remove it ....sounds good.
But to INSTALL ? .... what you suggest is toooo risky(IMO) ...you tweak the seal wrong and the trans has to come out - AGAIN.
And .... I HAVE to ask this question ... if you have been doing this for 30 years ....WHY don't you have the proper tool to do-it-right that costs less than a 10 spot ?
[Re: 469runner]
#145749
11/05/08 08:58 AM
11/05/08 08:58 AM
that how Ive done it as well. piece of cake. Clean up the mating surface well and use a LIGHT coat or rtv around the outside of the seal. grease the new seals rubber before installing the TC
[Re: 69Cuda340S]
#145751
11/05/08 10:40 AM
11/05/08 10:40 AM
RapidRobert
on the new seal going in I put some vaseline on the back side to keep the round spring from popping off & tap it in evenly with 2 small hammers at 3 o'clock & 9 o'clock & as mentioned sealer(permatex #2 for me)not RTV on the OD & some ATF on the ID.
[Re: dwbiggs]
#145753
11/06/08 03:53 PM
11/06/08 03:53 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Check your converter hub. If its worn or grooved it will never seal.
[Re: bobby66]
#145756
11/07/08 10:49 AM
11/07/08 10:49 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Don't make the same mistake I did...If you pull the pump, get new washers for the pump bolts. They're coated, and will only seal once. Also, Ultra Grey silicone works wonders in conjunction woth those washers.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: dwbiggs]
#145757
11/07/08 12:16 PM
11/07/08 12:16 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
I've had my tranny to shop 3 times in last 10 years...and still leaks out front Just whining...I have no meaningful input to offer.
Try running the trans a little on the low side, like 1 pint low when warm. 727s like to spit fluid out of the front breather and then it looks like the seal is leaking.
#145758
11/07/08 12:25 PM
11/07/08 12:25 PM
Posts: 4,884 Michigan
MNobody
That's the way my Dad taught me to do it, he was a mechanic for 36 year's. Clean up any burr's on the surface after you pry the old seal out, lightly sand the surface to clean it up, a little silicone on the outside of the new seal and tap it in straight.
[Re: MNobody]
#145759
11/07/08 02:36 PM
11/07/08 02:36 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
If your only changing the seal.Another old trick is to take the spring off the seal,spiral the connection to seperate ends and cut off 1/8" on the female side of the spring and spiral it back together for a tighter squeeze on the converter snout.
