727 Front Seal Replacement #145742
11/04/08 10:13 PM
11/04/08 10:13 PM
MARYLAND
69Cuda340S Offline OP
MARYLAND
My trans is out for an engine swap so I'd like to replace the front seal in the 727. Its not leaking but its been in there for over 10 years (less then 3000 miles though). What is the best way to get the old seal out?
Re: 727 Front Seal Replacement [Re: 69Cuda340S] #145743
11/04/08 10:16 PM
11/04/08 10:16 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Unless you have the tool ...I would take it to a trans shop. I would think that they would do-it for a 20-spot.
Re: 727 Front Seal Replacement [Re: 69Cuda340S] #145744
11/04/08 10:22 PM
11/04/08 10:22 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Get a screwdriver and knock it sideways, then grab with pliers and pull out. No big deal. Drive new seal in with a mallet ot small hammer evenly. Done deal. I've been doing it this way for 30 years.
Re: 727 Front Seal Replacement [Re: 469runner] #145745
11/04/08 10:29 PM
11/04/08 10:29 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A seal removal tool is easy to find and pretty cheap. You could make your own out of scrap metal if you had to.
Re: 727 Front Seal Replacement [Re: 469runner] #145746
11/04/08 10:32 PM
11/04/08 10:32 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
To remove it ....sounds good.
But to INSTALL ? .... what you suggest is toooo risky(IMO) ...you tweak the seal wrong and the trans has to come out - AGAIN.
And .... I HAVE to ask this question ... if you have been doing this for 30 years ....WHY don't you have the proper tool to do-it-right that costs less than a 10 spot ?
Re: 727 Front Seal Replacement [Re: dOrk !] #145747
11/04/08 10:40 PM
11/04/08 10:40 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Isn't hard to make a driver out of some PCV pipe. Popping the seal out is a simple job with out investing in special tools to do it. It will take you longer to find the tool, in the tool box than to improvise with a long thin screw driver and pop it out.
Re: 727 Front Seal Replacement [Re: MoparforLife] #145748
11/04/08 10:43 PM
11/04/08 10:43 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
PCV pipe ? ... that would have to be some THICK pipe to match the proper OD and ID you would need !!
Re: 727 Front Seal Replacement [Re: 469runner] #145749
11/05/08 08:58 AM
11/05/08 08:58 AM
that how Ive done it as well. piece of cake. Clean up the mating surface well and use a LIGHT coat or rtv around the outside of the seal. grease the new seals rubber before installing the TC
Re: 727 Front Seal Replacement #145750
11/05/08 10:06 AM
11/05/08 10:06 AM
MARYLAND
MARYLAND
Thanks for the replies. I used PVC pipe to drive in the rear trans seal when the trans was in the car. Worked great.
Re: 727 Front Seal Replacement [Re: 69Cuda340S] #145751
11/05/08 10:40 AM
11/05/08 10:40 AM
on the new seal going in I put some vaseline on the back side to keep the round spring from popping off & tap it in evenly with 2 small hammers at 3 o'clock & 9 o'clock & as mentioned sealer(permatex #2 for me)not RTV on the OD & some ATF on the ID.
Re: 727 Front Seal Replacement [Re: RapidRobert] #145752
11/06/08 02:59 PM
11/06/08 02:59 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
I've had my tranny to shop 3 times in last 10 years...and still leaks out front Just whining...I have no meaningful input to offer.
Re: 727 Front Seal Replacement [Re: dwbiggs] #145753
11/06/08 03:53 PM
11/06/08 03:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check your converter hub. If its worn or grooved it will never seal.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 Front Seal Replacement [Re: pittsburghracer] #145754
11/06/08 04:13 PM
11/06/08 04:13 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Regardless of how you remove or install. Test fit the new seal on the convertor BEFORE installing in the trans.
I've been down the road of aftermkt ft pump seals leaking on factory convertors. just an FYI
Re: 727 Front Seal Replacement [Re: gtx6970] #145755
11/07/08 08:10 AM
11/07/08 08:10 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You might as well change the front bushing while you've got it out.
Re: 727 Front Seal Replacement [Re: bobby66] #145756
11/07/08 10:49 AM
11/07/08 10:49 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Don't make the same mistake I did...If you pull the pump, get new washers for the pump bolts. They're coated, and will only seal once. Also, Ultra Grey silicone works wonders in conjunction woth those washers.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 727 Front Seal Replacement [Re: dwbiggs] #145757
11/07/08 12:16 PM
11/07/08 12:16 PM
MARYLAND
MARYLAND
Try running the trans a little on the low side, like 1 pint low when warm. 727s like to spit fluid out of the front breather and then it looks like the seal is leaking.
Re: 727 Front Seal Replacement #145758
11/07/08 12:25 PM
11/07/08 12:25 PM
MNobody Offline
MNobody  Offline
That's the way my Dad taught me to do it, he was a mechanic for 36 year's. Clean up any burr's on the surface after you pry the old seal out, lightly sand the surface to clean it up, a little silicone on the outside of the new seal and tap it in straight.
Re: 727 Front Seal Replacement [Re: MNobody] #145759
11/07/08 02:36 PM
11/07/08 02:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If your only changing the seal.Another old trick is to take the spring off the seal,spiral the connection to seperate ends and cut off 1/8" on the female side of the spring and spiral it back together for a tighter squeeze on the converter snout.
