BB oil pump failure
#1457440
06/24/13 09:25 AM
06/24/13 09:25 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Took the 72 beater for a little run. Mostly stock 440. Was already rebuilt when I found it in a truck. Seem to have either a high pressure or high volume pump. Got on it. WOT. Caught a nice scratch in 2nd. Hit 3rd and then let up. Valve train started rattle and look at the gauge, no oil pressure. Shut her down and ended up getting the trailer and towing it home. Drive gear and shaft are fine. Tried priming the pump, nothing. Changed out the pump, oil and filter. Primed right up. All seems to be good. No metal in oil. Never got over 180*. So what makes a pump fail? Took it apart and looks fine. Thinking that the by-pass valve let go?
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: BB oil pump failure
[Re: dOc !]
#1457442
06/24/13 10:33 AM
06/24/13 10:33 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Ive had a few go bad.Seems they just quit or the relief gets stuck.Ive only had one in 40 years that the rotors in the pump were bad.Ive also seen and heard Fram filters dropping the pressure to Zip.That and if the pickup wasnt cleaned it could be partly plugged and not sucking up enough oil on accel.Rocky
Chrysler Firepower
[Re: RapidRobert]
#1457445
06/24/13 12:03 PM
06/24/13 12:03 PM
moparmarks
I only run Wix filters. Maybe had 500 miles on it. I did try the filter on another motor and the pressure was fine. When I got the motor it was running good. Took it down to the long block. Very clean inside. Changed to a car pan and pickup. Again very clean inside. I drove it about 50 miles this weekend. No problems.
[Re: moparmarks]
#1457446
06/24/13 12:10 PM
06/24/13 12:10 PM
moparmarks
Heres the pump. Has some scaring but don't think that would cause an instant loss of pressure. Maybe a gradual loss. Shaft is tight in the rotor. It had 60psi at idle before this.
[Re: moparmarks]
#1457447
06/24/13 12:21 PM
06/24/13 12:21 PM
RapidRobert
Yes the rotors look fine. That is a strange case, I woulda sworn it was the filter & Wix does have a good rep
[Re: RapidRobert]
#1457449
06/24/13 12:28 PM
06/24/13 12:28 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
In the last 5 years I have had two bad wix filters on big blocks. They may be good filters but they aren't perfect.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: moparmarks]
#1457450
06/24/13 12:30 PM
06/24/13 12:30 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
How are you checking the shaft on the rotor fit by hand ? Same goes for the drive.
Put one end in a vice and vise grips tight on the shaft ...
[Re: Silver70]
#1457451
06/24/13 12:32 PM
06/24/13 12:32 PM
moparmarks
Had one for my CTD that they forgot the cut the threads on other than that I've had real good luck with Wix. I'm thinking it had to be the by-pass. Don't think it starved the mains.
[Re: JohnRR]
#1457452
06/24/13 12:36 PM
06/24/13 12:36 PM
moparmarks
Yep used a vise and vise grips.
[Re: dogdays]
#1457455
06/24/13 05:44 PM
06/24/13 05:44 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Pressure relief valve stuck open.
It's a positive displacement pump. That pump is simplicity itself. If the rotor turns, it pumps. If the inlet is clogged, it pumps nothing. If the outlet is plugged, it pumps until something gives.
If the shaft is spinning in the rotor, you'll see something. Either it'll weld itself back on (friction welding) or it will make the hole bigger.
Pressure relief valve stuck open means pump pumps, oil goes right back into crankcase. Engine sees no pressure. Judging from the appearance of the pump, that's what happened.
R.
I had the check valve on my race motor start sticking Friday(new motor, dyno time only and several runs 1/8 mile on it, it had above 160 lbs presure on the 200 lb gauge) when running the motor, I took the check valve out, it came out easily with the pump still on the motor, and cleaned it up. I didn't see any debris or scratches on it or in the Milidon dual line pump cover so I put it back on and started it up, I had cut the bypass spring down on this one already , the bypass would open at 80 lbs just like I wanted and had set it up on the dyno No more problems all weekend BTW, I am running the remote mounted HP6 type big Wix brand racing oil filter on this motor also
[Re: buildanother]
#1457459
06/24/13 11:32 PM
06/24/13 11:32 PM
JohnRR
U.S.S.A.
If that happened, the car would not run or at least start backfiring and all that, no?
Why would it? The shaft spinning the oil pump is spun by the gear which is spun by the cam and kept from coming up by the distributor. You could drop just a gear in there with no oil pump shaft and the engine would run ... not for very long though
