BB oil pump failure #1457440
06/24/13 09:25 AM
06/24/13 09:25 AM
Western Colorado High Desert
moparmarks Offline OP
Took the 72 beater for a little run. Mostly stock 440. Was already rebuilt when I found it in a truck. Seem to have either a high pressure or high volume pump.
Got on it. WOT. Caught a nice scratch in 2nd. Hit 3rd and then let up. Valve train started rattle and look at the gauge, no oil pressure. Shut her down and ended up getting the trailer and towing it home. Drive gear and shaft are fine. Tried priming the pump, nothing. Changed out the pump, oil and filter. Primed right up. All seems to be good. No metal in oil. Never got over 180*.
So what makes a pump fail? Took it apart and looks fine. Thinking that the by-pass valve let go?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: BB oil pump failure [Re: moparmarks] #1457441
06/24/13 09:47 AM
06/24/13 09:47 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
HOW does the rotor look ? ... and - with the other pump - you might have picked up some trash in the pan and it plugged the screen temporarily. I would consider dropping the pan ...
Re: BB oil pump failure [Re: dOoC] #1457442
06/24/13 10:33 AM
06/24/13 10:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive had a few go bad.Seems they just quit or the relief gets stuck.Ive only had one in 40 years that the rotors in the pump were bad.Ive also seen and heard Fram filters dropping the pressure to Zip.That and if the pickup wasnt cleaned it could be partly plugged and not sucking up enough oil on accel.Rocky
Chrysler Firepower
Re: BB oil pump failure [Re: therocks] #1457443
06/24/13 11:31 AM
06/24/13 11:31 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The rotor is pressed onto the shaft - friction fit! Probably the shaft is now spinning in the rotor. The rotor kit that used to be sold through Direct Connection had the rotor pinned to the shaft.
Re: BB oil pump failure [Re: moparmarks] #1457444
06/24/13 11:44 AM
06/24/13 11:44 AM
Put that filter that was on there back on & see if it's plugged. (1) filter collapsed (could happen especially if it is an F--- brand) (2) reg issue "unlikely but possible" (3) pickup severely plugged (not too likely but maybe). You definitely would want to find what it is (was) to avoid a repeat. If your real lucky it was the filter & fortunately that's the most likely. Holler what it ends up being
Re: BB oil pump failure [Re: RapidRobert] #1457445
06/24/13 12:03 PM
06/24/13 12:03 PM
I only run Wix filters. Maybe had 500 miles on it. I did try the filter on another motor and the pressure was fine. When I got the motor it was running good. Took it down to the long block. Very clean inside. Changed to a car pan and pickup. Again very clean inside. I drove it about 50 miles this weekend. No problems.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: BB oil pump failure [Re: moparmarks] #1457446
06/24/13 12:10 PM
06/24/13 12:10 PM
Heres the pump. Has some scaring but don't think that would cause an instant loss of pressure. Maybe a gradual loss. Shaft is tight in the rotor.
It had 60psi at idle before this.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: BB oil pump failure [Re: moparmarks] #1457447
06/24/13 12:21 PM
06/24/13 12:21 PM
Yes the rotors look fine. That is a strange case, I woulda sworn it was the filter & Wix does have a good rep
Re: BB oil pump failure [Re: RapidRobert] #1457448
06/24/13 12:28 PM
06/24/13 12:28 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
that shft can be tite enough where you cant spin it by hand but at higher rpm it will spin.
Re: BB oil pump failure [Re: RapidRobert] #1457449
06/24/13 12:28 PM
06/24/13 12:28 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
In the last 5 years I have had two bad wix filters on big blocks. They may be good filters but they aren't perfect.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: BB oil pump failure [Re: moparmarks] #1457450
06/24/13 12:30 PM
06/24/13 12:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How are you checking the shaft on the rotor fit by hand ? Same goes for the drive.
Put one end in a vice and vise grips tight on the shaft ...
Re: BB oil pump failure [Re: Silver70] #1457451
06/24/13 12:32 PM
06/24/13 12:32 PM
Had one for my CTD that they forgot the cut the threads on other than that I've had real good luck with Wix.
I'm thinking it had to be the by-pass. Don't think it starved the mains.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: BB oil pump failure [Re: JohnRR] #1457452
06/24/13 12:36 PM
06/24/13 12:36 PM
Yep used a vise and vise grips.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: BB oil pump failure [Re: JohnRR] #1457453
06/24/13 12:39 PM
06/24/13 12:39 PM
dogdays Offline
dogdays  Offline
Pressure relief valve stuck open.
It's a positive displacement pump. That pump is simplicity itself. If the rotor turns, it pumps. If the inlet is clogged, it pumps nothing. If the outlet is plugged, it pumps until something gives.
If the shaft is spinning in the rotor, you'll see something. Either it'll weld itself back on (friction welding) or it will make the hole bigger.
Pressure relief valve stuck open means pump pumps, oil goes right back into crankcase. Engine sees no pressure. Judging from the appearance of the pump, that's what happened.
R.
Re: BB oil pump failure [Re: dogdays] #1457454
06/24/13 12:45 PM
06/24/13 12:45 PM
Only 3 moving parts in the pump itself. Not a lot to go wrong.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: BB oil pump failure [Re: dogdays] #1457455
06/24/13 05:44 PM
06/24/13 05:44 PM
R.
I had the check valve on my race motor start sticking Friday(new motor, dyno time only and several runs 1/8 mile on it, it had above 160 lbs presure on the 200 lb gauge) when running the motor, I took the check valve out, it came out easily with the pump still on the motor, and cleaned it up. I didn't see any debris or scratches on it or in the Milidon dual line pump cover so I put it back on and started it up, I had cut the bypass spring down on this one already , the bypass would open at 80 lbs just like I wanted and had set it up on the dyno No more problems all weekend BTW, I am running the remote mounted HP6 type big Wix brand racing oil filter on this motor also
Re: BB oil pump failure [Re: Cab_Burge] #1457456
06/24/13 08:06 PM
06/24/13 08:06 PM
IN
ahy Offline
ahy  Offline
IN
You might also check the pump drive shaft or "distributor drive". On a stock shaft, the gear that engages the cam and spins the shaft is pressed on. With a high volume pump, a beefed gear is recommended with the gear pinned,the hex transition radiused and the hex hardened. I used the MP high strength shaft from Mancini.
If the gear spun on your shaft, it could do it again.
Re: BB oil pump failure [Re: ahy] #1457457
06/24/13 08:54 PM
06/24/13 08:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If that happened, the car would not run or at least start backfiring and all that, no?
Re: BB oil pump failure [Re: buildanother] #1457458
06/24/13 09:40 PM
06/24/13 09:40 PM
I've twisted two shafts off of stock Mopar OEM BB drives when junk got into the pumps and never heard of or saw a gear moving on them
Re: BB oil pump failure [Re: buildanother] #1457459
06/24/13 11:32 PM
06/24/13 11:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why would it? The shaft spinning the oil pump is spun by the gear which is spun by the cam and kept from coming up by the distributor. You could drop just a gear in there with no oil pump shaft and the engine would run ... not for very long though
