Will 16x8 with 4" BS fit on the front of a Duster?
#145731
11/04/08 09:54 PM
11/04/08 09:54 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Anyone know if a 16x8 inch rim with 4 inches of backspacing will fit on the front of a 72 Duster, it will be with 73 Duster big bolt brakes. Also the tires are 245/45ZR16.
Also another option is a 17x8 with 5.5 backspacing, any idea about that on the front?
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Will 16x8 with 4" BS fit on the front of a Duster?
[Re: 440Satellite]
#145733
11/04/08 10:07 PM
11/04/08 10:07 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Butch
I have 17X8 mustang wheels on the front of my 68 Barracuda, they have a 5.72" bs and fit fine. I'm using the late disk brake setup on my car as well. I don't think the 4" backspace will work, the tire/wheel will stick out too far, the OE spacing is 4.5" Remember measure twice as these are old mass produced cars and they do vary. HTH, Steve
[Re: Skeptic]
#145734
11/04/08 10:20 PM
11/04/08 10:20 PM
440Satellite
super gas
super gas
Hazlet, NJ
Thanks, I have a set of 17x8 with 5.5" BS Torq Thrust 2's on the back of my Duster( it has a wider F-Body big bolt rear). I'm about to put a disk brake setup off a 73 Duster on to add disk brakes and add the big bolt patern. I found a used set of 16x8's with a 4"BS and was wondering if if would work. But if it wont I'll just wait till I get the disk brakes on and try my 17x8's on the front, cause I'd like to go wider in the rear anyway( its got the springs moved in 3").
Butch
1972 Duster
318 4 speed
