Thanks,
I have a set of 17x8 with 5.5" BS Torq Thrust 2's on the back of my Duster( it has a wider F-Body big bolt rear). I'm about to put a disk brake setup off a 73 Duster on to add disk brakes and add the big bolt patern. I found a used set of 16x8's with a 4"BS and was wondering if if would work. But if it wont I'll just wait till I get the disk brakes on and try my 17x8's on the front, cause I'd like to go wider in the rear anyway( its got the springs moved in 3").
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
