Will 16x8 with 4" BS fit on the front of a Duster? #145731
11/04/08 09:54 PM
11/04/08 09:54 PM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Anyone know if a 16x8 inch rim with 4 inches of backspacing will fit on the front of a 72 Duster, it will be with 73 Duster big bolt brakes. Also the tires are 245/45ZR16.
Also another option is a 17x8 with 5.5 backspacing, any idea about that on the front?
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Will 16x8 with 4" BS fit on the front of a Duster? [Re: 440Satellite] #145732
11/04/08 09:56 PM
11/04/08 09:56 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I dont think so. I think you will hit the upper
arm or ball joint. It will be really close if it does.
Re: Will 16x8 with 4" BS fit on the front of a Duster? [Re: 440Satellite] #145733
11/04/08 10:07 PM
11/04/08 10:07 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Butch
I have 17X8 mustang wheels on the front of my 68 Barracuda, they have a 5.72" bs and fit fine. I'm using the late disk brake setup on my car as well. I don't think the 4" backspace will work, the tire/wheel will stick out too far, the OE spacing is 4.5" Remember measure twice as these are old mass produced cars and they do vary. HTH, Steve
Re: Will 16x8 with 4" BS fit on the front of a Duster? [Re: Skeptic] #145734
11/04/08 10:20 PM
11/04/08 10:20 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Thanks,
I have a set of 17x8 with 5.5" BS Torq Thrust 2's on the back of my Duster( it has a wider F-Body big bolt rear). I'm about to put a disk brake setup off a 73 Duster on to add disk brakes and add the big bolt patern. I found a used set of 16x8's with a 4"BS and was wondering if if would work. But if it wont I'll just wait till I get the disk brakes on and try my 17x8's on the front, cause I'd like to go wider in the rear anyway( its got the springs moved in 3").
Butch
