OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM #1457168
06/23/13 04:08 PM
06/23/13 04:08 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
OK, some may have read my post about my a/c compressor running constantly on my 95 Concorde. Fast forward to today.
Since I've owned this car, (probably 2.5 years) I've replaced the a/c compressor, this will be the 3rd. one. First one lasted till 2011, then replaced it with a known good in, it lasted probably 3/4 year, then it locked up, replaced it with another used one, it lasted 2 seasons. Now, let it go till this past weekend, bought a rebuilt one, replaced it and now it's locked up after about 24 hours !!!
Rec/dryers were replaced each time. Is there a way to flush out the system to correct this or should I just give up. I realize buying used compressors is not the wisest thing, but am I having a tough time picking used ones or is there something the system that's causing this perhaps?
I don't mind fixing something, but numerous times?!
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457169
06/23/13 04:25 PM
06/23/13 04:25 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Myself, I have never had a used or rebuilt refrigeration compressor be worth the cost difference.
I can't afford this. mark
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457170
06/23/13 04:29 PM
06/23/13 04:29 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
You need to flush the WHOLE system everytime there is a compressor failure, replace the orfice screen and receiver dryer. And quit buying someone else's junk. Are you adding oil with each replacement?
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457171
06/23/13 04:38 PM
06/23/13 04:38 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes they make cans of AC flush and you should be using them. Gotta get the metal form the failed compressors outta the system for a new comp to last.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: HemiRick] #1457172
06/23/13 04:46 PM
06/23/13 04:46 PM
S.E.Ohio
S.E.Ohio
A flush was never mentioned or was I billed for one, went to check old receipt, just r & r and charge + labor. Hmmmm.
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457173
06/23/13 08:13 PM
06/23/13 08:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Bill there is a block by the firewall.It acts like an orifice tube.I cant remember if they used an orifice tube that year or not.We always replaced the orifice as it has a fine screen to filter.Lots of places dont flush the system if the compressor didnt come apart inside.Most failures I did were bad clutches.Usually they cost as much as a reman compressor.Some you have to buy a complete compressor.They have flush kits at parts store.But you probally should clean the block on the firewall.They also can be replaced.Lines come off and it bolts to the evap connection.Its been a while since I tore one apart.Oh by the way reman compressors are usually a good buy.We used mostly 4 seasons.Rocky
Chrysler Firepower
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457174
06/23/13 08:25 PM
06/23/13 08:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1 - don't buy used a/c parts it's only asking for trouble.
2 - Replace the receiver drier
3 - Replace the orifice tube ( I don't think the 95's used an expansion valve in the system)
4 - Replace the condensor . they are a dual pass type that you will not get cleaned out no matter how hard you try
5 - avoid the cheap aftermkt compressors like a plague
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: gtx6970] #1457175
06/23/13 10:02 PM
06/23/13 10:02 PM
S.E.Ohio
S.E.Ohio
Thanks Guys!!
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457176
06/23/13 11:12 PM
06/23/13 11:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
From what I remember that uses an exspansion valve and not an orfice tube. If so then I would also replace the exspansion valve. Ron
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457177
06/24/13 01:13 AM
06/24/13 01:13 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You need to replace the condenser and evaporator. They can not be flushed and without doubt are contaminated after 3 compressor failures. The expansion valve is easy to check and clean, all the hoses need to be flushed too. Make sure the cooling fan comes on when it should. Fresh OE spec oil and NO STOP LEAK IN THE R-134a. No used or reman compressors, either. Not cheap or easy but you can do it right or do it over.
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Skeptic] #1457178
06/24/13 10:40 AM
06/24/13 10:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ron I though they still had the Expansion valve.Like I said nothing wrong with a reman compressor as long as its a quality one.Ive replaced a few hundred and only had 1 bad one and it just leaked.Warranty covered it.Rocky
Chrysler Firepower
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: therocks] #1457179
06/24/13 08:49 PM
06/24/13 08:49 PM
S.E.Ohio
S.E.Ohio
OK, going to replace the compressor, r/d, and the condensor. Already talked to someone about flushing it too.
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457180
06/24/13 10:36 PM
06/24/13 10:36 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
Don't use the same AC mechanic.
Contamination is likely killing your compressors.
Add an extra filter in front of the compressor.
Never use used AC parts on something you plan on keeping.
- What everyone else said.
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: 74RALLYE] #1457181
06/24/13 11:53 PM
06/24/13 11:53 PM
S.E.Ohio
S.E.Ohio
Don't use the same AC mechanic Already have someone else lined up
Add an extra filter in front of the compressor. Where are those available?
Lesson Learned
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: Magnumguy] #1457182
06/25/13 12:38 AM
06/25/13 12:38 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Is there an A/C clutch relay by any chance? I had one go out on another car and the compressor would run constantly until it locked the compressor up. If I shut the car off, sometimes it would keep power to the clutch...so if I disconnected the NEG and reconnected it I could hear a "click" everytime.
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: JoesMopar] #1457183
06/25/13 08:51 AM
06/25/13 08:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Bill we used to get filters from NAPA.I believe ant good parts store carries them.Make sure the lines get flushed also.Rocky
Chrysler Firepower
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: therocks] #1457184
06/25/13 02:08 PM
06/25/13 02:08 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Let me add-into this AC topic ..... my 03 daily-driver has a decent working system on it but it could be better. Are there any quickie "kits" that can be injected into the system to make it better ?
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: dOc !] #1457185
06/25/13 09:27 PM
06/25/13 09:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The quick charge kits with the gauge are decent.If its low they usually drop the temp some.I found best to have the system evacuated and vacuum drawn.Then recharge with the proper charge.Rocky
Chrysler Firepower
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: therocks] #1457186
06/26/13 09:22 AM
06/26/13 09:22 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Hay R .. are the kits cost effective ? ...or is the evac and vac a better deal ?.... what are the typical costs involved ?
Re: OK, WHAT'S GOING ON WITH MY AIR CONDITIONING SYSTEM [Re: dOc !] #1457187
06/26/13 11:58 AM
06/26/13 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The kits usually work decent if its just low.They all lose freon thru time and hoses,etc.Check the rad and condensor dosent have crap stuck to it.I usually turn on high and flush with cold water.You should feel the temp drop.Ive also seen a lot of older cars with contaminated freon.We always used a tester at work before we even touched a system.I had one the identifier said had benezyne etc in it.When you evac the stuff in the system goes into your tank and you dont want to contaminate a tank of clean stuff.We always used the stuff with dye in it.If there was or it develops a leak its easy to spot.Rocky
Chrysler Firepower
