Matching MP rocker arms for W2 Econo 995 heads?
#1457133
06/23/13 12:52 PM
06/23/13 12:52 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Folks...I picked up a set of new in the box W2 Econo heads a couple of years ago, these are the P4529995 MP part number.
My intended use for these is to replace the heavily ported '596 OEM castings on my 360 motor, probably the next build will be a stroker motor anyways, so slightly bigger cubes. This is a weekend driver/project car, not a drag racing vehicle, so the cam lift will never get beyond the .650 I'm thinking.
A set of MP rocker arms (P4876343) has come up locally for sale. Given that my W2 castings are the Long Valve versions, are there any specific MP rocker arms that need to be used in this application? Or will the P4876343 work?
The DCF-173 Instruction Sheet (see attachement) supplied with my W2 Econos references an older MP rocker arm number...so I have no idea if this is a workable combination or not. Given that both parts have been out of distribution chain for a few years now there is no information out there that I can find either.
Re: Matching MP rocker arms for W2 Econo 995 heads?
[Re: Diplomat360]
#1457135
06/24/13 09:53 PM
06/24/13 09:53 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
yes...
only difference in heads is the height of the pedestal which as you see takes the longer valves...you can see that the same part numbers for rocker arms are listed for both heads.
harland sharpe makes a complete kit for the econos...or crane make w2 rockers that can be used on the econo...they dont sell the complete kit just individual rockers...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Diplomat360]
#1457137
06/25/13 10:35 PM
06/25/13 10:35 PM
70AARcuda
las vegas
on the intake rockers..look at the offset..
W2 rockers take .775 offset intake rockers...both econo and race heads use the same rocker.
Tony
