A real starting line fiasco #1456800
06/22/13 10:29 PM
06/22/13 10:29 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
This all took place after my opponent and I had both lit the prestage light. The starter told us to hold. Then we both backed out of the lights about 10 feet. The starter came up to me and said they had a problem down the track and it would be fixed in a short. He gave me the option of going back through the water or staying where I was at. I said I would stay where I was. The other guy decided to go back through the water. The film starts from there. I had 3 guys telling me conflicting info ( if you can read sign language ). I finally assumed they wanted me to back through the water, which I did. I'm sure everything was plenty wet after a second time through the water. This was our 3rd time run of the evening, usually called the "one shot". The guy with the best package ( RT plus closest to your dial ) would win - gift certificate or around $100. My previous pass was a 10.72 so I dialed a 10.72. After all the starting line BS I had my worst RT and the car slipped and slid to a 10.92.
http://s79.photobucket.com/user/jcailey/media/MOV02448_zps04fa0190.mp4.html
Fastest 300
Re: A real starting line fiasco [Re: Crizila] #1456801
06/22/13 11:39 PM
06/22/13 11:39 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Didn't look like the tires got warm on the second burnout. No smoke.
Re: A real starting line fiasco [Re: rt66jim] #1456802
06/23/13 12:09 AM
06/23/13 12:09 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Why in the world is there 3 people telling you what to do ? crazy
Re: A real starting line fiasco [Re: rt66jim] #1456803
06/23/13 12:22 AM
06/23/13 12:22 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Yep. I think they got drowned .
Fastest 300
Re: A real starting line fiasco [Re: Crizila] #1456804
06/23/13 02:07 AM
06/23/13 02:07 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Personally I would never do a second burnout. It would take a very long "break" to get me to warm the tires again, they simply don't cool that fast. I have had a number of instances where I was shut down after a burnout for a number of reasons. Don't think I have ever done a second burnout after being shut off. Simply not needed unless it for an extended period of time. It is your car and you always make the call on whether or not to do a second burn out, the track cannot force you to do it. Just my
Re: A real starting line fiasco [Re: Crizila] #1456805
06/23/13 05:20 AM
06/23/13 05:20 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Wow they seemed quite lost on who does what!
I would have held up because they clearly had no right to force you in the water.
Count it as a learning experience.
Re: A real starting line fiasco [Re: MPerry] #1456806
06/23/13 09:10 AM
06/23/13 09:10 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I would not do another burnout either unless I sat for 15+ minutes. In fact I would barely back up to keep my tires near where they will launch. Sometimes the racers know more then the track help. I was at a big money race that allowed 2 time trials and had made a run in the left lane. Two cars remained and we were both looking for right lane. He pulled out, I pulled out behind him, that's when all hell broke loose. Track attendant waiving his arms, yelling, etc. trying to force me to run left lane. I calmly shut the car off, opened the door, and started to remove my seatbelts when his boss came running over, apologized to me and let Cory know of his mistake!! They do that to the ricers all the time on TnT night but not during a race.
I also sat on the starting line for 45mins one night knowing I should get out and change my dial due to deteriorating circumstances, but did not. Lost the race because of it... dumb
Re: A real starting line fiasco [Re: MegaDart] #1456807
06/23/13 10:26 AM
06/23/13 10:26 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
You have to be smarter than the track people. You said you told the starter that you did not want to go threw the burnout again. So when the other two guys were trying to get you to back up you should of just sat there and made the starter come up to the car and then you could of reminded him of the fact you did not want to do a burnout again.The only one knew you didn't want to back up was the starter so the other two guys had no clue.They thought in their minds that they were doing you a favor.Stick to your own way of doing burnouts and staging and if there is a problem try to have a plan and stay to that.I blame the starter then the track for having to many cheifs and not enough indians then you for not putting up some kind of a fuss so they would have to acually talk to you. If they did make you back up all you should of done was to the edge of the water box then do a quick hit then to the line.Not sticking up for the track people but they have to deal with many differant racers and most of the time its dam if you do and dam if you don't in a situation like that.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: A real starting line fiasco [Re: slippery440] #1456808
06/23/13 11:13 AM
06/23/13 11:13 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Yep, probably was my fault for not sticking to my - no second burnout plan. Should have used the "universal" one finger sign language on them.
Fastest 300
Re: A real starting line fiasco [Re: Crizila] #1456809
06/23/13 12:16 PM
06/23/13 12:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
looks like the CF that happens at our local track. dude if def telling you to back up.
Coming soon!!!!
Re: A real starting line fiasco [Re: Crizila] #1456810
06/23/13 12:21 PM
06/23/13 12:21 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Too many monkeys and not enough typewriters.
Re: A real starting line fiasco [Re: Mr.Yuck] #1456811
06/23/13 12:32 PM
06/23/13 12:32 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If there is a Safety issue(oil,parts,cars)on track they can hold you till the track is clear other than that let no one tell you what you must do!Unlike most if I sat over a couple of mins I like to do another Burn-Out,and make sure I do a harder & longer burn-out than normal.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: A real starting line fiasco [Re: Crizila] #1456812
06/23/13 12:35 PM
06/23/13 12:35 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Let them know you think they are # 1 with the finger,and motion them away from your car!
Re: A real starting line fiasco [Re: Dduster] #1456813
06/23/13 12:41 PM
06/23/13 12:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One thing about burnouts most forget is number one is to clean them secondary is heat. After tires set for a week they harden. The first good burnout gets the hard coating off then do an easy one next run to get the junk off that's picked up. Check your tires after the run and see how sticky they still are (all the rocks and junk stuck to them). Tire people LOVE to see those big smokey burnouts. There is rubber and VHT on the tract already you want your clean dry tires to stick to that. So you were right not to back up.
Re: A real starting line fiasco [Re: Crizila] #1456814
06/23/13 02:57 PM
06/23/13 02:57 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I'm sure all of us have had some type of starting line fiasco. At one of the tracks I race at during a specific time during the summer the setting sun will sit directly on top of the Xmas tree if you're in the left lane. It happened to me once during eliminations and as I staged I could not see the tree because the sun completely blinded me. This usually only lasts a few minutes because when the sun gets behind the tree you can see it. Anyway when I couldn't see the tree I backed out of staging and motioned to the starter that I couldn't see. He came over and verified the problem and was going to wait a moment. The tower told him to tell me to get staged or forfiet the round. I started fumbling around trying to put on a pair of sunglasses my crew man had. Anyway I finally delayed enough that when I did stage the sun was behind the tree and I won the round. After the run the track owner and I had a few heated words because I have seen him stop the race for 5 minutes before so the sun could move. He never did that to me again.
Re: A real starting line fiasco [Re: Al_Alguire] #1456815
06/23/13 04:53 PM
06/23/13 04:53 PM
Lehigh Acres, Florida
rickstershemi Offline
Ditto....never be intimidated by the starting line crew....
Rickster
