Re: REPLACED COMPRESSOR AND R/D, NOW WHY......
[Re: Magnumguy]
#1456738
06/22/13 08:43 PM
06/22/13 08:43 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
If it was low on refrigerant, the compressor clutch would cycle on and off quickly. I suppose that if it were over charged, or very hot and humid, it would take a long time before it cycled off??? Is the compressor engaged, and blowing cold air?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Magnumguy]
#1456740
06/22/13 09:24 PM
06/22/13 09:24 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
with it idling, pull the plug on the compressor, and see if it stops running. the clutch might be stuck, unless you see it stopping, by using the dash controls?
[Re: GO_Fish]
#1456743
06/23/13 01:05 AM
06/23/13 01:05 AM
Posts: 10,646 S.E.Ohio
Magnumguy
S.E.Ohio
What's your outside temp when you did your test?
mid-upper 80's and humid
[Re: Magnumguy]
#1456744
06/23/13 01:28 PM
06/23/13 01:28 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Bill it will run a lot when hot and humid.there is a sensor built in that shuts the A/C off when the evap gets around 32 degrees so it dosent freeze.That and the hi pressure switch will shut it off if it gets too high.Not uncommon for it to run a lot with high temps.Rocky
Chrysler Firepower
[Re: therocks]
#1456745
06/23/13 04:03 PM
06/23/13 04:03 PM
Magnumguy
S.E.Ohio
