REPLACED COMPRESSOR AND R/D, NOW WHY...... #1456737
06/22/13 08:33 PM
06/22/13 08:33 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
....isn't my compressor cycling? It isn't noisy or anything, but it won't cycle on and off, just like the old days.
Any ideas? Will it hurt it?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: Magnumguy] #1456738
06/22/13 08:43 PM
06/22/13 08:43 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If it was low on refrigerant, the compressor clutch would cycle on and off quickly. I suppose that if it were over charged, or very hot and humid, it would take a long time before it cycled off??? Is the compressor engaged, and blowing cold air?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: GO_Fish] #1456739
06/22/13 09:10 PM
06/22/13 09:10 PM
S.E.Ohio
S.E.Ohio
It is working fine, got to blowing 40 deg. air. It was cycling before I replaced the compressor. It really doesn't bother me it doesn't, as long as it's not a problem.
I actually undercharged it a bit on purpose as my gauges are old and I don't entirely trust them.
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: Magnumguy] #1456740
06/22/13 09:24 PM
06/22/13 09:24 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
with it idling, pull the plug on the compressor, and see if it stops running. the clutch might be stuck, unless you see it stopping, by using the dash controls?
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: Golden-Arm] #1456741
06/22/13 09:38 PM
06/22/13 09:38 PM
S.E.Ohio
S.E.Ohio
Oh, it turns off (quits turning) when a/c is turned off, but when it's on, it's on too stay!
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: Magnumguy] #1456742
06/23/13 12:24 AM
06/23/13 12:24 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
What's your outside temp when you did your test?
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: GO_Fish] #1456743
06/23/13 01:05 AM
06/23/13 01:05 AM
S.E.Ohio
S.E.Ohio
mid-upper 80's and humid
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: Magnumguy] #1456744
06/23/13 01:28 PM
06/23/13 01:28 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Bill it will run a lot when hot and humid.there is a sensor built in that shuts the A/C off when the evap gets around 32 degrees so it dosent freeze.That and the hi pressure switch will shut it off if it gets too high.Not uncommon for it to run a lot with high temps.Rocky
Chrysler Firepower
Re: REPLACED COMPRESSOR AND R/D, NOW WHY...... [Re: therocks] #1456745
06/23/13 04:03 PM
06/23/13 04:03 PM
S.E.Ohio
S.E.Ohio
Cool!! (sorry...)
