Comp XE274H-10 good repl.for 284/.484 purple?
#1456660
06/22/13 07:13 PM
06/22/13 07:13 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Clonerunner issues found: Previous owner used steel shim head gaskets,(no copper coat or anything) was not religious about using coolant and apparently did not retorque many a year ago (10) when motor was built.(some headbolts felt like 30 lbs or so)Pistons look nice, especially the two that were sucking water regularly.Flat tops w/valve reliefs.no P/N yet. Heads look OK, valves etc, still shows crosshatch in cylinder walls,but it has CAM-ITIS! One lobe shows tell tale discoloration and graininess.Not 100% sure, but is purple and supposed to bee 284/.484.Loved it! Comp has XE 274H-10 split pattern (230/236@.050) adv.274/286-.488/.491 110' lobe separation and I can get amazon free freight, and I think a 25.00 rebate. Would this be pretty close to, or better for my setup? (383 .030 906s,approx 3000 stall,3.55s,# 3800,eddy rpm intake/850 DP 3" exh w/x pipe) It ran very strong w/the purple.No complaints, so I almost wanted the same cam, but maybe the split pattern would work better for me? Thoughts? Bear
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: Comp XE274H-10 good repl.for 284/.484 purple?
[Re: Exit1965]
#1456666
06/23/13 03:13 PM
06/23/13 03:13 PM
Sixgun
Western Washington
Decisions, decisions... Thanks all, food for thought.Maybe not so simple as a "magic" updated grind will make the sun come out, I'll lose 20 lbs, and the angels will sing. As for the 850 carb,it was a really clean 4 corner I had that was gathering dust,ran a boatload better than the Mighty D it replaced, and Hot Rod used the same carb for their infamous 383 intake shootout IIRC.Plus I didn't have anything else good at the time. More to follow, heads are off, time to buy a cam. Thanks, C
[Re: dogdays]
#1456668
06/23/13 08:33 PM
06/23/13 08:33 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
A better Comp cam all around is the XE275HL. It has real Chrysler lobes, the 274 is a Chevy lobe cam. It will surprise you. If you liked the 484 cam the 275 will be better. R.
I am looking at cams as well, and thought this recomemdation sounded good.
But isn't the .525 lift on this pt # cam a tadd much ????
[Re: gtx6970]
#1456669
06/24/13 12:39 AM
06/24/13 12:39 AM
Sixgun
Western Washington
My thought also about the .525 lift...traditional wisdom (IIRC) was with a stock 906 head, .500 lift was about it.You could go bigger,but the heads only flow so much in stock form anyway, at least up to that magic #.However,I do like the sound of the testimonial. Are there less "radical" grinds on a chrysler lobe that are under .500? This thing had steel shim gaskets,would be .020 compressed, so a 'regular'fel-pro is like .038 compressed, so right there is another "bonus" .018 PV clearance.I have never done the clay the piston deal, ever.Theoretically, if I re-install the purple 284/484 (or equivalent) there should be no clearance issues.If I go bigger, I'm sort of in uncharted territory.This motor had stamped steel rockers also, I am anticipating needing adj. rockers and correct length pushrods, as they will need to be "longer" by .018 with the comp. head gaskets.Yes????
[Re: Sixgun]
#1456670
06/24/13 01:28 AM
06/24/13 01:28 AM
Posts: 2,141 junction city oregon
viperblue72
The comp 274 is nothing similar to a 284/484. If you have a good set of headers, I would not worry about a split pattern. You are going to lose a lot of top end with the 274 compared to the 284. But it would be a good cam choice imo. It's not going to make more power though if that is what you are looking for. Also what is your compression ratio? As far as higher lift than the heads flow, it will still hold the valve open at or above .500 for a longer time, therefore you still gain power. If you catch my drift.
[Re: viperblue72]
#1456671
06/24/13 12:51 PM
06/24/13 12:51 PM
dogdays
The more modern cam, XE275HL, will probably have more duration at 0.200 lift than the .484. I think you'll see an increase in max horsepower.
As far as rockers go, pick the cam, (mine is best), install it, see if preload is OK. If not, get a set of pushrods the right length. I bet your existing valvegear except for springs will be OK. The only problem with higher lift is you need springs and retainer-to-guide clearance for it. Piston-to-valve clearance is something to check, but most bigblock Mopars have the pistons down so far that it is a non-issue. And if you replace a steel shim head gasket with a composition gasket to increase P/V clearance, you deserve whatever loss of performance you get. R.
[Re: dogdays]
#1456672
06/24/13 02:19 PM
06/24/13 02:19 PM
Sixgun
Western Washington
Good information, good thoughts, dogdays, viperblue. Looking at a set of used ductiles, as I am not a gambling man, and these rockers had 'acceptable' preload as far as I can tell,reasonably sure that'll go away. The pistons do not appear to be KBs,no part number visible,pretty good wedge shaped clearance notch running across them, slightly deeper for the intake valve.Will be checking how far down in the hole they sit,just on GP. As far as replacing a steel shim gasket with a composition and "deserving" the power loss I get, sorry, my love affair with 60's technology only goes so far. Not doing this for the P/V clearance, I am doing this 'cause they FAILED.(whether mis installed, not retorqued, whatever) Sealing technology has advanced light years since they built these motors.Ditto for cam technology, hence the look at newer grinds. No steel shims, thanks. Not worth the what is it, .2 potential compression point gain? With what passes for gasoline these days, it is not even a question anymore for me.Got a leftover set of custom detroits from Dan D I'll probably use. Still deciding if I want to use the 440 source heads I have,too. Thanks for all the input!Onwards!
[Re: viperblue72]
#1456674
06/25/13 04:24 AM
06/25/13 04:24 AM
Sixgun
Western Washington
Unfortunately,these are the 1st gen "take your chances" heads.May go ahead anyway, what am I going to save them for?Good opportunity,Will run them by my friendly machine shop to check for the legendary tight guide and general valve job re-check issues. Interestingly enough, the fellow at 44o source highly recommended the very 274 grind we are discussing for his gen 1 heads with my application.(I didn't even tell him what I was thinking, he popped up with that recommendation.).The Comp cam tech line guy Chris, stated unequivocably (whew, 10$ word) that they use chrysler blanks for chrysler cams, and he wishes the forums would let that one die??? He also likes the 274.Still thinking.
[Re: Sixgun]
#1456676
06/25/13 12:37 PM
06/25/13 12:37 PM
Of course they use Chrysler blanks for Chrysler cams. What else could they use? Doesn't mean that the lobes ground onto those blanks weren't originally developed for a Chevy, or that they are designed to take full advantage of the Chrysler .904 lifter.
