Re: STUPID QUESTION
[Re: MIKES_DUSTER]
#1456587
06/22/13 05:00 PM
06/22/13 05:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Same direction as the distributor.
BB - looking at the hex CCW SB - looking at the hex CW
Re: STUPID QUESTION
[Re: Supercuda]
#1456588
06/22/13 05:04 PM
06/22/13 05:04 PM
Posts: 6,301 colorado
a12superbee
colorado
When you pull the drive out make sure you didn't twist the tip off of the shaft.
I can't afford this.
mark
Re: STUPID QUESTION
[Re: MIKES_DUSTER]
#1456596
06/22/13 10:56 PM
06/22/13 10:56 PM
RapidRobert
Drill priming or even hand priming will kick up far in excess of the 10lbs you are showing. Either a lifter is out of its' bore or a gallery plug is missing or there's an issue on the suction side (pickup/pump regulator)
Re: STUPID QUESTION
[Re: MIKES_DUSTER]
#1456600
06/23/13 12:06 AM
06/23/13 12:06 AM
RapidRobert
Didn't know it was roller lifters. Mike, holler what it ends up being
