Can u get a solid roller lifter that's a true ,904"? #1456198
06/21/13 09:14 PM
06/21/13 09:14 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
This is for a HEMI
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456199
06/21/13 10:14 PM
06/21/13 10:14 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
yes,this company can make anything you want
Chris Johnson 818 647-6155
Re: Can u get a solid roller lifter that's a true ,904"? [Re: boatracer572] #1456200
06/21/13 10:16 PM
06/21/13 10:16 PM
San Jose Ca.
San Jose Ca.
2
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456201
06/21/13 10:30 PM
06/21/13 10:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Nice!!! But something tells me I might not be able to afford em!!! LOL
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456202
06/22/13 12:06 AM
06/22/13 12:06 AM
San Jose Ca.
San Jose Ca.
$1300 a set,I have two sets one with bushed rollers and a set with needle rollers.most of the NHRA pro stock field is running cam fx lifters.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: boatracer572] #1456203
06/22/13 09:40 AM
06/22/13 09:40 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
wow, thats more than I would like to spend.
My cam is just a street solid roller grind.
I have crowers and they are ,903" and I have too much lifter to bore clearance.
I was wondering if any off the shelf solid roller lifter comes in a true ,904" diameter.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456204
06/22/13 09:59 AM
06/22/13 09:59 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Get them coated
Re: Can u get a solid roller lifter that's a true ,904"? [Re: Leon441] #1456205
06/22/13 10:07 AM
06/22/13 10:07 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I just ran the P2843177, but they also are not a true 904.
I think they are .0005 under.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Can u get a solid roller lifter that's a true ,904"? [Re: BB65Barracuda] #1456206
06/22/13 03:56 PM
06/22/13 03:56 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Why would you not just bush the lifter bores?
Re: Can u get a solid roller lifter that's a true ,904"? [Re: mac56] #1456207
06/22/13 04:44 PM
06/22/13 04:44 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
they are already bronze bushed but I have like 0.003 clearance at least.
I was wondering if I could get off the shelf roller lifters that are a true ,904"
but I guess IM gonna pull the trigger, remove the old bushings install new ones and incorporate an oiling hole given the bushings currently in my block are blind and I kinda dont like that. Id rather have some oil in there....cant hurt!
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456208
06/22/13 07:32 PM
06/22/13 07:32 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456209
06/22/13 08:48 PM
06/22/13 08:48 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
If your already bushed Domingo pushing new bushings in is definitely the way to go.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456210
06/24/13 01:14 PM
06/24/13 01:14 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
A few thousandths(for clearance) won't make any difference for what your wanting. It's a street car and not a super/stocker.. right?
Jesel makes a true 904 lifter. They run about 3k new. I have a couple sets of barely used
but they take *special block prep*..machining.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: 52savoy] #1456211
06/24/13 01:55 PM
06/24/13 01:55 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Like I said, I already have bronze lifter bushings n my block....and the clearance is more than 0.025"
I can fit a 0.0025" gauge in between the lifter bore and lifter.
Seems the true ,904" lifters are more expensive than replacing my lifter bushings so I guess Im gonna replace my lifter bushings.
In any case, my lifter bushings are also blind, so this time around Id like to incorporate a small lubrication hole in them.
Would you guys run it like this????
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456212
06/24/13 01:56 PM
06/24/13 01:56 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
0.0025"
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456213
06/24/13 02:06 PM
06/24/13 02:06 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'd trust the reading of a pair of dial calipers before I'd trust sticking a feeler gauge in there
For an accurate measurement, dial bore gauge
Re: Can u get a solid roller lifter that's a true ,904"? [Re: roadhazard] #1456214
06/24/13 02:55 PM
06/24/13 02:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that is not the the best way to measure the clearance , an inside snap gauge would be better.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: JohnRR] #1456215
06/24/13 03:07 PM
06/24/13 03:07 PM
Or a barrel micrometer ( I hope that is the correct name of them), adjustable small hole gauge
Re: Can u get a solid roller lifter that's a true ,904"? [Re: Cab_Burge] #1456216
06/24/13 04:36 PM
06/24/13 04:36 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I know thats not the right way of measuring the clearance.
But if I can stick a feeler gauge thats 0,0025" in there common sense tells me that actual clearance is even more than that.
I just did that quickly when I noticed it had a lot of slop, since using my dial caliper is kinda hard on there.....
I would do it with a dial bore gauge....if I had one handy.
Re: Can u get a solid roller lifter that's a true ,904"? [Re: domingo] #1456217
06/24/13 04:47 PM
06/24/13 04:47 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Ill take it to the machine shop to get an accurate measurement with a dial bore gauge before doing anything else....
I cant get an accurate measurement with a caliper.
