Can u get a solid roller lifter that's a true ,904"?
#1456198
06/21/13 09:14 PM
06/21/13 09:14 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Re: Can u get a solid roller lifter that's a true ,904"?
[Re: mac56]
#1456207
06/22/13 04:44 PM
06/22/13 04:44 PM
domingo
EL Master
EL Master
Lima, Peru
Why would you not just bush the lifter bores?
they are already bronze bushed but I have like 0.003 clearance at least.
I was wondering if I could get off the shelf roller lifters that are a true ,904"
but I guess IM gonna pull the trigger, remove the old bushings install new ones and incorporate an oiling hole given the bushings currently in my block are blind and I kinda dont like that. Id rather have some oil in there....cant hurt!
[Re: domingo]
#1456209
06/22/13 08:48 PM
06/22/13 08:48 PM
Posts: 976 ontario canada
mac56
ontario canada
If your already bushed Domingo pushing new bushings in is definitely the way to go.
[Re: 52savoy]
#1456211
06/24/13 01:55 PM
06/24/13 01:55 PM
domingo
EL Master
EL Master
Lima, Peru
A few thousandths(for clearance) won't make any difference for what your wanting. It's a street car and not a super/stocker.. right? Jesel makes a true 904 lifter. They run about 3k new. I have a couple sets of barely used but they take *special block prep*..machining.
Like I said, I already have bronze lifter bushings n my block....and the clearance is more than 0.025"
I can fit a 0.0025" gauge in between the lifter bore and lifter.
Seems the true ,904" lifters are more expensive than replacing my lifter bushings so I guess Im gonna replace my lifter bushings.
In any case, my lifter bushings are also blind, so this time around Id like to incorporate a small lubrication hole in them.
Would you guys run it like this????
[Re: domingo]
#1456212
06/24/13 01:56 PM
06/24/13 01:56 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: roadhazard]
#1456214
06/24/13 02:55 PM
06/24/13 02:55 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I'd trust the reading of a pair of dial calipers before I'd trust sticking a feeler gauge in there
For an accurate measurement, dial bore gauge
that is not the the best way to measure the clearance , an inside snap gauge would be better.
