large dodge truck 318 poly question #1455905
06/21/13 04:39 AM
06/21/13 04:39 AM
levittown pa
fstfish66 Offline OP
levittown pa
looking for info on a large ?? dodge truck from around 1959/60 maybe some oen knows or has seen one, with a 318 poly motor with an unusuall timing chain cover ,,raised up water pump mounting area to get the water pump up higher then usuall to the middle of the radiator.,,, an y one seen one of these ?? thanks
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: fstfish66] #1455906
06/21/13 08:06 AM
06/21/13 08:06 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
That's the industrial/heavy duty version. Sometimes referred to as a 318-3 I believe.
Re: large dodge truck 318 poly question [Re: fstfish66] #1455907
06/21/13 09:35 AM
06/21/13 09:35 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I wouldn't mined having one of those timing covers laying around.
Just a question....didn't the early(late 50's to the early 60's) poly motors(277-318) have extended cranks?
Moparlee
Re: large dodge truck 318 poly question [Re: Robbins] #1455908
06/21/13 12:56 PM
06/21/13 12:56 PM
dogdays Offline
dogdays  Offline
Yup.
R.
Re: large dodge truck 318 poly question [Re: Robbins] #1455909
06/21/13 10:57 PM
06/21/13 10:57 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
There is one sitting in the OKC pull a part in the truck section.
Don't these also have three hole bolt covers?
Re: large dodge truck 318 poly question [Re: moparpollack] #1455910
06/24/13 12:44 AM
06/24/13 12:44 AM
levittown pa
levittown pa
I WOULD BE VERY INTERESTED IN THAT ONE SITTING IN THE PICK A PART IF ITS THE CORRECT TIMING COVER,, THE 277 241 270 315 325 331 ETC POLY MOTORS DID HAVE AN EXTENDED CRANK,,THEY HAVE NOTHING IN COMMON WITH THE 1959 THRU 1966 POLY 318, THE ONLY PART THAT INTERCHANGES BETWEEN SOME OF THEM IS THE DISTRIBUTOR, THATS WHY ALL THE EARLY POLY AND EARLY HEMI MOTORS WENT OUT OF PRODUCTION,,TO COSTLY NOTHING INTERCHANGED,, ITS SAD THE EARLY POLY MOTORS MADE GOOD POWER AND HAVE COOl VALVE COVERS,,,THE 1959 THRU 1966 POLY 318 IS THE BASES OF WHAT WE KNOW AS THE LA small block
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: fstfish66] #1455911
06/24/13 12:54 AM
06/24/13 12:54 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You most likely have seen a 361-413 series. I have had d600 trucks from the 60's and that were all lower conventional pump/drive systems.
Re: large dodge truck 318 poly question [Re: NITROUSN] #1455912
06/24/13 01:00 AM
06/24/13 01:00 AM
levittown pa
levittown pa
NOPE A FRIEND OF MINE JUST BOUGHT A 1940 PLYMOUTH WITH A LA 318 WITH A LARGE TRUCK POLY TIMING COVER, RASIED WATER PUMP MOUNTING I KNOW THE DIFFERENCE BETWEEN A 318 AND A 413 THANKS FOR THE REPLY
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: fstfish66] #1455913
06/24/13 08:23 AM
06/24/13 08:23 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Post some pics of this motor.....????
Re: large dodge truck 318 poly question [Re: NITROUSN] #1455914
06/24/13 09:09 PM
06/24/13 09:09 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
And dump the caps..
I am truckless..
Re: large dodge truck 318 poly question [Re: 340SHORTY] #1455915
06/24/13 09:55 PM
06/24/13 09:55 PM
Lehigh Acres, Florida
rickstershemi Offline
And dump the caps..
Wow Larry never realized you were so sensitive....they say it's good to let your feminine side show from time to time.
Rickster
Re: large dodge truck 318 poly question [Re: rickstershemi] #1455916
06/24/13 10:24 PM
06/24/13 10:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Caps and Posi's in Mopars..
I am truckless..
Re: large dodge truck 318 poly question [Re: 340SHORTY] #1455917
06/24/13 11:09 PM
06/24/13 11:09 PM
Re: large dodge truck 318 poly question [Re: 340SHORTY] #1455918
06/25/13 04:52 AM
06/25/13 04:52 AM
levittown pa
levittown pa
And dump the caps..
sorry caps was so i could read it,, nothing more
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: NITROUSN] #1455919
06/25/13 04:56 AM
06/25/13 04:56 AM
levittown pa
levittown pa
yes i wanted too before we put the water pump on it, but didnt get a pic before ill make sure to get the best pic i can soon,,,
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: fstfish66] #1455920
06/26/13 10:42 AM
06/26/13 10:42 AM
Colorado
Hem1orange Offline
Hem1orange  Offline
Colorado
Does it look any thing like this?
413 water pump engine.
Ron
Re: large dodge truck 318 poly question [Re: Hem1orange] #1455921
06/27/13 08:55 AM
06/27/13 08:55 AM
levittown pa
levittown pa
Ron
hard to tell looking at the back of the motor,,but from what i can see its appears to be the same,,only on a small block,, ill get pic of it as soon as i can thanks
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: fstfish66] #1455922
06/27/13 09:40 AM
06/27/13 09:40 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I realize that the poly/Early Hemi are different from the Early 277-318 motors I just thought that I either ran into an extended crank one or I was reading about them........can't remember now it's been too long since I had the early 318.
I used to have one in a 66 step side truck when I was 15 after I put it in there.
I have seen a picture on eBay once of a nice 57 Dodge truck that had a newer sb in an it had a raised water pump/timing cover on it. Worked nice for the way it was sitting in there.
It look to take the same water pump(as the newer motors) it was just raised up....other than seeing that picture I haven't every seen one up close..........I studied the picture for awhile trying see what I was looking at........I assumed that it was from a big truck application.
Moparlee
Re: large dodge truck 318 poly question [Re: Robbins] #1455923
06/27/13 05:01 PM
06/27/13 05:01 PM
levittown pa
levittown pa
yes the early poly/hemi motor had an extended crank,,,the early 331 ci chrysler hemi also had an extended bell housing that was part of the block,kind of weird
2015 cherokee
2013 R/T classic
Re: large dodge truck 318 poly question [Re: fstfish66] #1455924
07/05/13 03:30 AM
07/05/13 03:30 AM
levittown pa
levittown pa
here are a few pics of this 1959/60 dodge truck poly 318 timing cover ,,,see how it raises the water pump up,, im looking for one ,,, i have one located if the owner wants to sell it thanks for looking
2015 cherokee
2013 R/T classic
