large dodge truck 318 poly question
#1455905
06/21/13 04:39 AM
06/21/13 04:39 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
looking for info on a large ?? dodge truck from around 1959/60 maybe some oen knows or has seen one, with a 318 poly motor with an unusuall timing chain cover ,,raised up water pump mounting area to get the water pump up higher then usuall to the middle of the radiator.,,, an y one seen one of these ?? thanks
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
Re: large dodge truck 318 poly question
[Re: fstfish66]
#1455907
06/21/13 09:35 AM
06/21/13 09:35 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I wouldn't mined having one of those timing covers laying around.
Just a question....didn't the early(late 50's to the early 60's) poly motors(277-318) have extended cranks?
Moparlee
[Re: Robbins]
#1455908
06/21/13 12:56 PM
06/21/13 12:56 PM
dogdays
[Re: Robbins]
#1455909
06/21/13 10:57 PM
06/21/13 10:57 PM
moparpollack
Lil Herman
Lil Herman
85086
There is one sitting in the OKC pull a part in the truck section.
Don't these also have three hole bolt covers?
[Re: moparpollack]
#1455910
06/24/13 12:44 AM
06/24/13 12:44 AM
fstfish66
levittown pa
I WOULD BE VERY INTERESTED IN THAT ONE SITTING IN THE PICK A PART IF ITS THE CORRECT TIMING COVER,, THE 277 241 270 315 325 331 ETC POLY MOTORS DID HAVE AN EXTENDED CRANK,,THEY HAVE NOTHING IN COMMON WITH THE 1959 THRU 1966 POLY 318, THE ONLY PART THAT INTERCHANGES BETWEEN SOME OF THEM IS THE DISTRIBUTOR, THATS WHY ALL THE EARLY POLY AND EARLY HEMI MOTORS WENT OUT OF PRODUCTION,,TO COSTLY NOTHING INTERCHANGED,, ITS SAD THE EARLY POLY MOTORS MADE GOOD POWER AND HAVE COOl VALVE COVERS,,,THE 1959 THRU 1966 POLY 318 IS THE BASES OF WHAT WE KNOW AS THE LA small block
[Re: fstfish66]
#1455911
06/24/13 12:54 AM
06/24/13 12:54 AM
Posts: 18,422 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You most likely have seen a 361-413 series. I have had d600 trucks from the 60's and that were all lower conventional pump/drive systems.
[Re: fstfish66]
#1455913
06/24/13 08:23 AM
06/24/13 08:23 AM
NITROUSN
NOPE A FRIEND OF MINE JUST BOUGHT A 1940 PLYMOUTH WITH A LA 318 WITH A LARGE TRUCK POLY TIMING COVER, RASIED WATER PUMP MOUNTING I KNOW THE DIFFERENCE BETWEEN A 318 AND A 413 THANKS FOR THE REPLY
Post some pics of this motor.....????
[Re: 340SHORTY]
#1455915
06/24/13 09:55 PM
06/24/13 09:55 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
And dump the caps..
Wow Larry never realized you were so sensitive....they say it's good to let your feminine side show from time to time.
Rickster
[Re: NITROUSN]
#1455919
06/25/13 04:56 AM
06/25/13 04:56 AM
fstfish66
levittown pa
yes i wanted too before we put the water pump on it, but didnt get a pic before ill make sure to get the best pic i can soon,,,
[Re: fstfish66]
#1455922
06/27/13 09:40 AM
06/27/13 09:40 AM
Robbins
Joplin, MO USA
I realize that the poly/Early Hemi are different from the Early 277-318 motors I just thought that I either ran into an extended crank one or I was reading about them........can't remember now it's been too long since I had the early 318.
I used to have one in a 66 step side truck when I was 15 after I put it in there.
I have seen a picture on eBay once of a nice 57 Dodge truck that had a newer sb in an it had a raised water pump/timing cover on it. Worked nice for the way it was sitting in there.
It look to take the same water pump(as the newer motors) it was just raised up....other than seeing that picture I haven't every seen one up close..........I studied the picture for awhile trying see what I was looking at........I assumed that it was from a big truck application.
Moparlee
[Re: Robbins]
#1455923
06/27/13 05:01 PM
06/27/13 05:01 PM
fstfish66
levittown pa
yes the early poly/hemi motor had an extended crank,,,the early 331 ci chrysler hemi also had an extended bell housing that was part of the block,kind of weird
[Re: fstfish66]
#1455924
07/05/13 03:30 AM
07/05/13 03:30 AM
fstfish66
levittown pa
here are a few pics of this 1959/60 dodge truck poly 318 timing cover ,,,see how it raises the water pump up,, im looking for one ,,, i have one located if the owner wants to sell it thanks for looking
