how to clean an oily cooling system #1455789
06/20/13 08:32 PM
06/20/13 08:32 PM
utah
jjl Offline OP
jjl  Offline OP
utah
A friend has a suburban and we need to know what to use.
formally orangemonster
Re: how to clean an oily cooling system [Re: jjl] #1455790
06/20/13 08:44 PM
06/20/13 08:44 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Tide laundry detergent and dawn dishwasher detergent have both been used with success. Flush system with water, fill with water and detergent and run engine till hot. Drain flush, repeat if necessary.
Re: how to clean an oily cooling system [Re: Pacnorthcuda] #1455791
06/21/13 06:46 PM
06/21/13 06:46 PM
Amherst,NY
challengermike Offline
Amherst,NY
Cascade dish washer soap. work great.
Re: how to clean an oily cooling system [Re: challengermike] #1455792
06/22/13 08:51 PM
06/22/13 08:51 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
i used Lestoil on several Neons with trans cooler failure's that filled the engine with ATF+4
Works perfectly
Re: how to clean an oily cooling system [Re: challengermike] #1455793
06/23/13 12:39 AM
06/23/13 12:39 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
X2
It cuts oil and grease and it doesn't make suds. Have used it many times to clean up after an NTC Cummins oil cooler failure.
Drain the cooling system and fill it up with Cascade and water. Run it up to temp and let it circulate for 5-10 minutes. Dump it and repeat. Dump it again and flush with clean water. Should be squeaky clean after.
Nasty black diesel engine oil is likely harder to get out than ATF and the cooling system is a 1/3 the size so you could try the fresh water flush after the first dose and check for residue and then repeat if necessary.
I think we used to dissolve 1 box of Cascade to a 5 gal pail of water or as much as would dissolve.
Kevin
Re: how to clean an oily cooling system [Re: Twostick] #1455794
06/23/13 09:14 PM
06/23/13 09:14 PM
Ohio
Todd Offline
Todd  Offline
Ohio
At the dealership we use simple green. We tried the dish washing liquid but the simple green was a lot faster.
