70 B body PDB problem. #1455308
06/19/13 12:08 PM
06/19/13 12:08 PM
Kelowna, B.C. Canada
DPelletier Offline OP
OK, I am FINALLY attempting to get my car on the road after nine years, two wheelbarrows full of cash and one "Christine" incident where the car tried to kill me.
It seems that the front brakes are locking on. As soon as I start the engine and the booster gets vaccuum, the front brakes are on even without touching the pedal. Car off; wheels turn just fine. I took the master off and started the car and the booster pushrod moves about 1/8" as soon as you start the engine...my buddy tells me that isn't supposed to happen and that makes sense to me....any other theories or possibilities?
Full disclosure: I bought the car with no brake linkage, no booster and no master cylinder so the wrong parts are definitely a possibility. The master cyl appears correct so if it's the culprit, it's probably a bad rebuild....the booster wasn't rebuilt.
any comments are appreciated. This car is the ultimate test of my patience!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 B body PDB problem. [Re: DPelletier] #1455309
06/19/13 12:13 PM
06/19/13 12:13 PM
Andrewh Online content
Andrewh  Online Content
there is an internal valve in the booster.
had one go bad on me, and while driving it slowly applied the brakes till they were full on.
didn't realize it, till I found I had my foot on the floor with the gas and barely doing the speed limit.
smoked the fronts.
so yeah, bad booster.
Re: 70 B body PDB problem. [Re: Andrewh] #1455310
06/19/13 01:04 PM
06/19/13 01:04 PM
Thanks; makes sense. wondered why the car was constantly spinning the rear tires!
