Hemi dip stick. #1454998
06/18/13 08:20 PM
06/18/13 08:20 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Does anybody make a pre bent oil dip stick and tube for use on a 426 hemi with TTI headers? I'm tried of trying to bend one up. Help.
Re: Hemi dip stick. [Re: 71birdJ68] #1454999
06/18/13 08:50 PM
06/18/13 08:50 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I'm using the Mopar chrome tube with my TTI Headers. If $$ is no object go shopping at Lokar. They make all kinds of flexible dip sticks.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hemi dip stick. [Re: 71birdJ68] #1455000
06/18/13 09:00 PM
06/18/13 09:00 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I don't think anyone makes one. I ruined a couple repo tubes trying to rebend them. I finally just bought the Milodon flexible dipstick.
Re: Hemi dip stick. [Re: HEMIDOG 70] #1455001
06/18/13 09:19 PM
06/18/13 09:19 PM
Morristown Tn.
Morristown Tn.
Yes, I have been pulling my hair out trying to make one that looks stock.
Re: Hemi dip stick. [Re: 71birdJ68] #1455002
06/19/13 12:32 AM
06/19/13 12:32 AM
IN
ahy Offline
ahy  Offline
IN
I run the re-pop MOPAR stick on my B stroker. With minor tweaking it fits between the header flange and head pipe. I tried the flex Milodon stick and the oil was wiped off by the bends. I tried the Mancini stick for use with headers and it fit fine on the engine stand but didn't play nice with PS in the engine compartment. The re-pop stick worked best. Minor PITA to pull it when pulling headers but no biggie.
Re: Hemi dip stick. [Re: ahy] #1455003
06/19/13 12:36 AM
06/19/13 12:36 AM
The 426 Hemiroids are way different on thier dipsticks and tubes when compared to the wedges of all years and types
Re: Hemi dip stick. [Re: Cab_Burge] #1455004
06/19/13 01:20 AM
06/19/13 01:20 AM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
So the only dip stick tube that you can buy now is a repop that resembles a stock style tube or OEM.
1971 HEMI E BODY REGISTRY
Re: Hemi dip stick. [Re: hemicar1971] #1455005
06/19/13 01:43 AM
06/19/13 01:43 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I tapped the dip stick hole, put in a NPT to compression fitting and used a piece of big brake line and bent it to fit. Now I just undo the compression fitting if I need to remove the dipstick and no one sees the fitting. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hemi dip stick. [Re: astjp2] #1455006
06/19/13 06:40 AM
06/19/13 06:40 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
That's a really good idea! Wish I would have came up with that.
I used a re-pop from Mancini's and still ended up making a little bracket that attached to the second header bolt at #1 on my Hemi / TTI set up.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Hemi dip stick. [Re: BB65Barracuda] #1455007
06/19/13 11:36 AM
06/19/13 11:36 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Along that line a friend bent one from trans/brake line and brazed a finish nail cut and looped around the tube. After fitting the tube he cur to lenght rather than re-marking the stick.
When done it looked original.
Re: Hemi dip stick. [Re: srt] #1455008
06/19/13 03:11 PM
06/19/13 03:11 PM
California
mickm Offline
mickm  Offline
California
i mangled a few as well, but finally have one that fits. it is snug against the header, so i don't even have a bracket. should probably do that, but it's in there tight.
just takes a little time and making very small bends each time. test the dipstick for travel all the way through the tube with each new bend. you will get to a point that the dipstick won't go past the major bend right before it goes into the block, and then you're kind of stuck.
Re: Hemi dip stick. [Re: 71birdJ68] #1455009
06/19/13 03:39 PM
06/19/13 03:39 PM
Morristown Tn.
Morristown Tn.
I tore up a $70 repo tube. I've tried copper and aluminum,after 4 or 6 times that gets expensive too. Schumacher used to have on that worked with TTI's but their supplier won't make anymore for some reason. So I am going to try one that Mancini Racing says will work. I'll give an update when I get it.
Re: Hemi dip stick. [Re: 71birdJ68] #1455010
06/19/13 03:51 PM
06/19/13 03:51 PM
MICHIGAN
MICHIGAN
The one I used was the one Mancini said would work with the TTI's.
It did After I built the bracket!
I did this Before the motor was in the car Even otherwise Id still be working on it...
Re: Hemi dip stick. [Re: mickm] #1455011
06/19/13 04:10 PM
06/19/13 04:10 PM
California
mickm Offline
mickm  Offline
California
oh yeah, forgot to say that.
out of the car, minutes.
in the car with headers on, hours.
Re: Hemi dip stick. [Re: mickm] #1455012
06/19/13 04:54 PM
06/19/13 04:54 PM
an8sec70cuda Offline
I use the Milodon flexible braided dipstick. I bought a couple different factory style dipsticks when I first started putting my hemi together. After mangling them up trying to get them to fit like I wanted around my TTI 2 1/4" headers, I bought the Milodon piece.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi dip stick. [Re: an8sec70cuda] #1455013
06/25/13 04:45 AM
06/25/13 04:45 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I just started on my exercise-in-futility last Sat. Bought a 3/8" fuel line. Put 2 single flare clamps on it facing each other about a 1/4" apart. Put 2 C-clamps on them & created a little hump to catch the block. All it needs is a tiny swell.
Needed a nasty first bend to clear the Schumacher bolt for a socket to fit. (made a socket wrench weld-ment to clear the TTI's 2&1/8" #1 primary if needed) The dip stick gets real tuff at the last bend, ... but choking up on it gets it past that then she's fine. I figured that tight bend might wipe the oil but so far its fine.
The shinny spot is where my 80's bought flaring clamp/vise kept sliding. The other one was my dad ~60's clamp, ...that bit like it's supposed to.
Re: Hemi dip stick. [Re: thehemikid] #1455014
06/25/13 04:59 AM
06/25/13 04:59 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I'm planning on taking a little out of that last upper bend so the tube will be parallel to the header flange & weld a bracket for a flange bolt.
But all this may not matter if the tube doesn't clear the P/S box & high pressure hose & fitting. I still have to test fit to the K-member/PS box mounted on a K-member dolly.
Re: Hemi dip stick. [Re: thehemikid] #1455015
06/25/13 05:07 AM
06/25/13 05:07 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I'd like for it to come out about here, but it does look pretty tight in that area, ...we'll see.
Re: Hemi dip stick. [Re: thehemikid] #1455016
06/25/13 09:03 AM
06/25/13 09:03 AM
MICHIGAN
MICHIGAN
Don't take this the wrong way, Ive just ran into the same issues with my coronet.
Have you put the dipstick in it yet?
Looks good but putting the dipstick in and out may be a little tough with such a sharp bend. How is removal of the tube? It being on the side with the starter if you ever have to loosen up the header to change the starter " and you will!" that tube may have to come out so you can finagle the starter out and back in.
Re: Hemi dip stick. [Re: BB65Barracuda] #1455017
06/25/13 10:47 AM
06/25/13 10:47 AM
Morristown Tn.
Morristown Tn.
UPDATE: Well, I got the one that Mancini said would work with headers. It didn't as does a lot of what they sell. I cut the tab off and made a slight bend and reused the mount tab that came with the repo kit.Now it works, but this was with the motor out of the car. I also talked to the man that actually makes these and he said that he was going to do some research on what the problem was with the fit. He was very nice and said he would re work it or fix it if I tore it up,a refreshing difference from most people that supply stuff for us. I also was able to use the fire sleeve and the white cover that goes on the handle from the repo kit, except for the location most people won't know it from a stock one.
