Re: Hemi dip stick.
[Re: 71birdJ68]
#1454999
06/18/13 08:50 PM
06/18/13 08:50 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I'm using the Mopar chrome tube with my TTI Headers. If $$ is no object go shopping at Lokar. They make all kinds of flexible dip sticks.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hemi dip stick.
[Re: hemicar1971]
#1455005
06/19/13 01:43 AM
06/19/13 01:43 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I tapped the dip stick hole, put in a NPT to compression fitting and used a piece of big brake line and bent it to fit. Now I just undo the compression fitting if I need to remove the dipstick and no one sees the fitting. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Hemi dip stick.
[Re: mickm]
#1455012
06/19/13 04:54 PM
06/19/13 04:54 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I use the Milodon flexible braided dipstick. I bought a couple different factory style dipsticks when I first started putting my hemi together. After mangling them up trying to get them to fit like I wanted around my TTI 2 1/4" headers, I bought the Milodon piece.
Re: Hemi dip stick.
[Re: thehemikid]
#1455016
06/25/13 09:03 AM
06/25/13 09:03 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Don't take this the wrong way, Ive just ran into the same issues with my coronet. Have you put the dipstick in it yet? Looks good but putting the dipstick in and out may be a little tough with such a sharp bend. How is removal of the tube? It being on the side with the starter if you ever have to loosen up the header to change the starter " and you will!" that tube may have to come out so you can finagle the starter out and back in.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
