valve body removal an install #1454699
06/18/13 03:23 AM
06/18/13 03:23 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok guy's I got my trans for my 81 d150 an I want to install the new valve body I bought from a member on here, the 1 I bought has a tf-3 kit installed, I have never messed with this so if ya have a step by step pdf or something that would be sweet lol.. the tranny is already removed from the truck.
drive fast, drive hard, DRIVE MOPAR
Re: valve body removal an install [Re: lifted85] #1454700
06/18/13 03:26 AM
06/18/13 03:26 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
do you have access to a Mopar service manual ?
Re: valve body removal an install [Re: dOoC] #1454701
06/18/13 04:56 AM
06/18/13 04:56 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
i do not, I got a Hayne's manual for a dodge truck floating around some where in my box of stuff, I had a guy that was going to do it for me but with time running out for the car show in august an him blowing me off I cant wait any longer
Re: valve body removal an install [Re: lifted85] #1454702
06/18/13 08:31 AM
06/18/13 08:31 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
just be careful of the neutral safety switch when putting it back in. the little plastic piece on the valve body is fragile and breaks easily, ask me how I know.
Re: valve body removal an install [Re: 65rbdodge] #1454703
06/21/13 02:41 AM
06/21/13 02:41 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
that's a problem because I don't know how to remove 1. my Hayne's give's zero info on the job so any 1 got some info I can use??
Re: valve body removal an install [Re: lifted85] #1454704
06/21/13 03:00 AM
06/21/13 03:00 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Can you BORROW a Mopar service manual at your local larger library ?
Re: valve body removal an install [Re: dOoC] #1454705
06/21/13 05:23 AM
06/21/13 05:23 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Go to the shift kit manufacturers website, you should be able to download instructions.
There may be some things you have to do in the case too.
Re: valve body removal an install [Re: lifted85] #1454706
06/21/13 09:01 AM
06/21/13 09:01 AM
PA
BTTG Offline
BTTG  Offline
PA
If it has a 727 buy this book!
http://www.amazon.com/Torqueflite-A-727-...ords=munroe+727
I had never touched a transmission and I put a TF2 in my 727 and would of never gotten the job done with just the transgo directions. It's simple particularly with the trans out of the car as you said it is.
Re: valve body removal an install [Re: lifted85] #1454707
06/21/13 05:10 PM
06/21/13 05:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The video in the link below shows the VB removal procedure, the tailhousing has been removed so it's easier but to make the removal easier with the tail installed place the shifter in Park (lever all the way back) and turn the output shaft until it clicks into Park.
http://www.youtube.com/watch?v=c9O3lnHMuMA
The TF-3 mod includes mods to the case, not just the valve body.
