'96 Cummins oil pressure gauge issues #1454479
06/17/13 03:44 PM
06/17/13 03:44 PM
cumminsexpress99 Offline OP
oil pressure is running on the low side on factory oil pressure gauge, a shop installed a second one separately, they tapped in right about the oil filter housing. the gauge has been running on the low side about 25, now has totally dropped off. Is there a better place to tap into, or is there build up cause the gauge to be off.
Re: '96 Cummins oil pressure gauge issues [Re: cumminsexpress99] #1454480
06/17/13 07:35 PM
06/17/13 07:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe your pressure is that low. I would remove the factory sender and check the pressure with a known good gauge.
Re: '96 Cummins oil pressure gauge issues [Re: NITROUSN] #1454481
06/17/13 10:14 PM
06/17/13 10:14 PM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
I run my aftermarket oil pressure sender off the oil filter housing, can't get much better than that, 25psi warm idle is normal on all my 12valves, I'd get uneasy lower than that. Maybe a leaky seal on turbo? Tired engine? Probably a number of things it could be.
-j
Re: '96 Cummins oil pressure gauge issues [Re: jimbob101] #1454482
06/18/13 08:57 PM
06/18/13 08:57 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Check your oil pressure with a good quality MECHANICAL gauge. I have little faith in a electrical oil pressure gauge. FWIW, it is not uncommon for the factory gauge to be way off.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
