oil pressure is running on the low side on factory oil pressure gauge, a shop installed a second one separately, they tapped in right about the oil filter housing. the gauge has been running on the low side about 25, now has totally dropped off. Is there a better place to tap into, or is there build up cause the gauge to be off.
