DEI Titanium exhaust wrap #1453890
06/16/13 04:15 PM
06/16/13 04:15 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Hey guys what is the trick when using this type of wrap, not to end up with a bunch of loose strings during the wrap process. The DEI is different than the Cool It Thermo Tec.
Re: DEI Titanium exhaust wrap [Re: tee-john] #1453891
06/16/13 04:54 PM
06/16/13 04:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Haven't had the loose string problem. I overlap the starting point, overlap each pass about 25-30%, and at the ends I'll use a metal tie-wrap, or a hose clamp if I need to unwrap it in the future for servicing or access. If I use a hose clamp, I always trim the length of the tail during mock-up for a clean appearance and to prevent catching something on it.
Re: DEI Titanium exhaust wrap [Re: topside] #1453892
06/16/13 05:14 PM
06/16/13 05:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Like when you have to replace the thermally disintegrated tube it is insulating
Re: DEI Titanium exhaust wrap [Re: jcc] #1453893
06/16/13 08:07 PM
06/16/13 08:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
...that could be, but I only run the stuff near the starter and those cars don't see rain. No problems yet (fingers crossed).
