91 dakota drive belt #1453620
06/16/13 12:24 AM
06/16/13 12:24 AM
Alton, IL
Dakota_Don Offline OP
Alton, IL
anyone have a 91 dakota? is that the first year of the serp belt? Do you have any pics of the drive belt system, i need pics of tensioner? a/c? pwr steer and alt.. thanks
Re: 91 dakota drive belt [Re: Dakota_Don] #1453621
06/16/13 03:20 AM
06/16/13 03:20 AM
usa
franks lil red Offline
usa
hello. yes i do have a 91 dakota v8. i got the pics you want but there to big to post here and i am not able to make them smaller. i could e mail them to you if that would help. let me know
Re: 91 dakota drive belt [Re: franks lil red] #1453622
06/17/13 08:15 PM
06/17/13 08:15 PM
usa
usa
test
Re: 91 dakota drive belt [Re: franks lil red] #1453623
06/17/13 08:18 PM
06/17/13 08:18 PM
usa
usa
2
Re: 91 dakota drive belt [Re: franks lil red] #1453624
06/17/13 08:19 PM
06/17/13 08:19 PM
usa
usa
3
Re: 91 dakota drive belt [Re: franks lil red] #1453625
06/17/13 08:20 PM
06/17/13 08:20 PM
usa
usa
Re: 91 dakota drive belt [Re: franks lil red] #1453626
06/17/13 08:20 PM
06/17/13 08:20 PM
usa
usa
Re: 91 dakota drive belt [Re: franks lil red] #1453627
06/17/13 08:44 PM
06/17/13 08:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Why do you have a magnum in a 91.?
Re: 91 dakota drive belt [Re: buildanother] #1453628
06/17/13 09:24 PM
06/17/13 09:24 PM
usa
usa
i seen that lid at the pull and pay and got it for a buck.
Re: 91 dakota drive belt [Re: franks lil red] #1453629
06/18/13 01:17 AM
06/18/13 01:17 AM
Alton, IL
Alton, IL
wow that helps a-lot.. i am wanting to put a serp belt on my 72 LA engine, and the magnum system wont work on a LA engine, but seems like the 91 Dak will if i can find one..
Re: 91 dakota drive belt [Re: buildanother] #1453630
06/18/13 10:12 PM
06/18/13 10:12 PM
ky.
K
kenworth_goose Offline
K
ky.
That ain't a magnum engine!
Re: 91 dakota drive belt [Re: Dakota_Don] #1453631
06/18/13 10:13 PM
06/18/13 10:13 PM
ky.
K
K
ky.
The magnum setup will work on the older la style engines.
Re: 91 dakota drive belt [Re: kenworth_goose] #1453632
06/20/13 08:03 PM
06/20/13 08:03 PM
Alton, IL
Alton, IL
no the mag set will not work with LA heads.. the cover water pump and and main accessory will, how ever the tensioner and pwr steer will not work on the older LA headed engines..the 91 LA engine in the dakota was by-itself and is what i am looking for.. I alos thought the mag set (93 3.9 v6) was a bolt on, till i got to the tensioner and pwr steering, and no way to bolt them up unless i fab some brackets.. I also just verified my find with Rick E-burger of mopar action as well.
Re: 91 dakota drive belt [Re: Dakota_Don] #1453633
06/20/13 08:06 PM
06/20/13 08:06 PM
Alton, IL
Alton, IL
the only way to make the mag setup completely work is to swap to mag heads.. the mag heads have bolt holes for the tensioner and pwr steer bracket, LA heads do not have all the holes
Re: 91 dakota drive belt [Re: franks lil red] #1453634
06/20/13 08:10 PM
06/20/13 08:10 PM
Alton, IL
Alton, IL
Does your pump just bolt to the accessory bracket? with the hole show in this pics??
Re: 91 dakota drive belt [Re: Dakota_Don] #1453635
06/20/13 08:11 PM
06/20/13 08:11 PM
Alton, IL
Alton, IL
cuz if thats the case, i can make this pump work, then fab up just the tensioner bracket
Re: 91 dakota drive belt [Re: Dakota_Don] #1453636
06/20/13 09:57 PM
06/20/13 09:57 PM
Alton, IL
Alton, IL
i did find this web page that has lots of explodes diagrams of mag and non mag brackets ect...
here is the magnum set up
http://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=535601&ukey_product=4485306
the LA is here http://www.factorychryslerparts.com/show...essor%20bracket
pwr steer bracket LA 5.2 http://www.factorychryslerparts.com/show...g=power+bracket
Re: 91 dakota drive belt [Re: franks lil red] #1453637
06/20/13 11:39 PM
06/20/13 11:39 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Lower with the camera shows the belt routing
Re: 91 dakota drive belt [Re: 76dodgeboy] #1453638
06/24/13 05:38 PM
06/24/13 05:38 PM
Alton, IL
Alton, IL
I love searching for a needle in a hay stack
Re: 91 dakota drive belt [Re: Dakota_Don] #1453639
06/24/13 07:20 PM
06/24/13 07:20 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Power steering pump bolts directly to the timing cover with those three bolts.
