Advice on '84 Ramcharger #1453496
06/15/13 08:44 PM
06/15/13 08:44 PM
Anderson, SC
resqguy Offline OP
resqguy  Offline OP
Anderson, SC
My stepson, who lives in Reno NV, just bought an 84 Ramcharger. I'm not a truck guy and I live in NC. The truck is an auto with the 360.
It is in good shape but any truck that old is likely to have issues. This is my stepson's 1st truck but he is mechanically inclined. His friend is recommending that he replace the ThermoQuad. He says that they can leak gas and don't work well in offroad situations. I know TQs are often misunderstood.
The carb needs rebuilding. Should he replace it, if so what should he replace it with? Are they worth rebuilding?
Re: Advice on '84 Ramcharger [Re: resqguy] #1453497
06/15/13 09:25 PM
06/15/13 09:25 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I'd rebuild it. That truck if stock has a BUNCH of emission controls that interface with the carb.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Advice on '84 Ramcharger [Re: 3hundred] #1453498
06/15/13 09:31 PM
06/15/13 09:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I took my TQ fishing, replaced it with a Q Jet. Couldnt be happier.
I am truckless..
Re: Advice on '84 Ramcharger [Re: 3hundred] #1453499
06/15/13 09:38 PM
06/15/13 09:38 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not really alot of emissions in 84. mainly smog pump. At least that's all my 84 Had and we hooked the smog pump
Re: Advice on '84 Ramcharger [Re: resqguy] #1453500
06/15/13 10:01 PM
06/15/13 10:01 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
why not invite him to the forum, and have him pop in the truck forum?
Re: Advice on '84 Ramcharger [Re: 76dodgeboy] #1453501
06/15/13 10:33 PM
06/15/13 10:33 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
So what did you do with the venturi vacuum port, evaporative emission hose(s) and EGR? There's a couple more but it's been too many years. I think there were 9 or 10 vacuum lines and maybe an electic solenoid hookup for the evaporative system? I can't remember now if the CTS hooked to the carb or not?
Holley used to offer a replacement, list 7855 if I remember.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Advice on '84 Ramcharger [Re: 3hundred] #1453502
06/15/13 10:53 PM
06/15/13 10:53 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Didn't have all that crap. Had same about of stuff on motor my 78 did other than smog pump. Don't recall a bunch of vacuum lines etc.
Re: Advice on '84 Ramcharger [Re: 76dodgeboy] #1453503
06/16/13 12:17 AM
06/16/13 12:17 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The Q Jet I used was off a Dodge truck.
I am truckless..
Re: Advice on '84 Ramcharger [Re: 340SHORTY] #1453504
06/16/13 01:10 AM
06/16/13 01:10 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
84 should have been near the end of the Thermoquad production. I believe Dodge replaced them with Q-jets in 85.
Having owned many Thermoquads, rather then rebuild it, I would replace it. Personally, swapping in an efi system would be 1st choice, followed by an AFB or Edelbrok, which would be 2nd choice, but many have had good luck with Q-jets. Gene
Re: Advice on '84 Ramcharger [Re: resqguy] #1453505
06/17/13 11:01 AM
06/17/13 11:01 AM
Anderson, SC
resqguy Offline OP
resqguy  Offline OP
Anderson, SC
Thanks for the help. Shane is just getting back on his feet. He is doing fine but he can't afford to do the wrong thing with the truck.
Re: Advice on '84 Ramcharger [Re: resqguy] #1453506
06/17/13 12:07 PM
06/17/13 12:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Rebuild it and if he doesn't like it upgrade.
Re: Advice on '84 Ramcharger [Re: 76dodgeboy] #1453507
06/17/13 10:59 PM
06/17/13 10:59 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
