727 How much fluid?? #1453173
06/15/13 11:23 AM
06/15/13 11:23 AM
England
P
pete walton Offline OP
P
England
Just had my trans rebuilt ,,,deep pan ,big cooler ,,,,How much trans fluid should it take ??? my car is a race car only and at some stage the dip sick and tube has been cut down .... I have been told to stick 8 litres in it ,,,,I do not fancy wrecking Best part of £1500 worth of John Copes finest parts,,,,thanks in advance
Re: 727 How much fluid?? [Re: pete walton] #1453174
06/15/13 12:14 PM
06/15/13 12:14 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think if you tell us the length of the tube we can help by the stock measurement.
Re: 727 How much fluid?? [Re: pete walton] #1453175
06/15/13 12:23 PM
06/15/13 12:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Get a factory tub & stick, if possible & just recalibrate ur stick.
Re: 727 How much fluid?? [Re: pete walton] #1453176
06/15/13 12:55 PM
06/15/13 12:55 PM
Pull the trans pan off before you put fluid in it and see how much the dipstcik sticks out of the dipstick tubes, if it is even with the bottom of the tube start with 6 quarts,(is nix sprecken zee litres , dang Yanks ) and then start the motor up with the tranny in nuetral, move the shifter from forward to reverse several times and then check the fluid level, add fluid until it reads between the end( tip) of the stick and the add mark when cold, do not overfill it so it reads above the full mark when hot Especially with a deep pan Why not try contacting John Cope and ask him what initial fill to use
Re: 727 How much fluid?? [Re: pete walton] #1453177
06/15/13 06:32 PM
06/15/13 06:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The FULL mark on the factory dipstick is 1/4" (6.3mm) above the ledge where the tube plugs in.
Re: 727 How much fluid?? [Re: pete walton] #1453178
06/15/13 07:02 PM
06/15/13 07:02 PM
tn
robnbird Offline
robnbird  Offline
tn
I use 9 qts with a deep pan and a 8" converter
