360 noisey lifters #145274
11/03/08 07:27 PM
11/03/08 07:27 PM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
Hi
And thanks ahead of time
when the car sits for a couple of days the lifters are noisy on start up til the oil pressure builds, also I assume they are not operating the valves either cause of the ruffness of the idle once it warms up it goes...I never reve up an engine cold..Please confirm what I think I know or assum
mike
Re: 360 noisey lifters [Re: mikepar] #145275
11/03/08 07:33 PM
11/03/08 07:33 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I've got the same problem and i hate it
It's not an old engine, it's been doing it off and on for years now.
I use 20/50 and grit my teeth till it clears.
When I finish the Challenger I'll open it up and swap the lifters, I hope that works.
Re: 360 noisey lifters [Re: mikepar] #145276
11/03/08 10:27 PM
11/03/08 10:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Install some good quality lifters, IE: comp cams etc. break them in properly and your problem should go away. Contrary to what you may be told, all lifters are not made equally. They may be made by the same comapy but their are different levels of QUALITY
AGAIN IE: bin 1, bin 2 bin, bin 3, or border line rejects
Tim
Re: 360 noisey lifters [Re: mikepar] #145277
11/03/08 10:38 PM
11/03/08 10:38 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I can't remember who it is, but there is a member here that swears by Shell Rotella full synthetic 5W-40, and he says it almost eliminated all start-up noise. The Rotella is also said to contain over 1200 ppm of zinc which is enough for the flat tappet cams BTW. I'm thinking of using it for my next oil change.
Re: 360 noisey lifters [Re: mikepar] #145278
11/03/08 10:42 PM
11/03/08 10:42 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
A solid lifter cam is the best answer to the problem. Flat lifters and hyd in particular have been a real problem for years,Comp Cams is the best place I've found to buy the cheapest crap in the market. It's a shame since I grew up a few miles from them,but haven't spent with them in years,they really are the last company I'd look to for answers,but their marketing is a real $$$.
Re: 360 noisey lifters [Re: mikepar] #145279
11/04/08 12:00 AM
11/04/08 12:00 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Probably your rods rattling........get rid of the Fram filter.
My 360 did that after the rebuild. Bye-bye Fram! Problem solved!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 360 noisey lifters [Re: mikepar] #145280
11/04/08 08:46 AM
11/04/08 08:46 AM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
yah im usin 10 30 synthetic I thought a new cam and lifters in the spring I gotta do the water pimp anyways the older one that the bottom hose exits to the drives side with a timing cover to match
Re: 360 noisey lifters [Re: mikepar] #145281
11/04/08 10:05 AM
11/04/08 10:05 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i agree with the Comp crap. they have changed thier lifters recently and are crap. they used to be silver in the middle and have CC lazer etched in there and an extra ring cut around the top. they looked good. now they look like the 100.00 dollar cam kit ones. no name just raw cast in the middle. i have 4 that are clicking. one that was stuck in the bottom. had to hone the piston in it to get it to move. it is still sticking till full oil press. hits it.
called them they say pull the cam and send it all to them. they should send me some new lifters so i could take the parts out of them till i get a working set.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: 360 noisey lifters [Re: 65cuda] #145282
11/04/08 01:41 PM
11/04/08 01:41 PM
Cincinnati, OH
68red440 Offline
68red440  Offline
Cincinnati, OH
My new Comp Cam lifters do the same thing. I made sure the rockers are adjusted properly, good oil pressure and flow to the heads, etc. I also found that they pump down in less than a couple hours by pulling a valve cover, pushing down on pushrods, and rotating the engine around. Every time it sits for a couple hours or more, I need to let them pump up before driving off. Otherwise it runs great when it's warmed up.
Re: 360 noisey lifters [Re: 68red440] #145283
11/04/08 06:36 PM
11/04/08 06:36 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I had good luck with crower lifters in the past but I don`t know if they are still made in the USA.
