Amp guage burnt out! #1452522
06/13/13 08:00 PM
06/13/13 08:00 PM
P.E.I. eastern Canada
N
newportrider Offline OP
N
I borrowed a buddies car for my daughters prom. The freakin amp guage just burnt out!! Need a quick fix for Saturday any suggestions? Its a 66 Newport ambulance.
Re: Amp guage burnt out! [Re: newportrider] #1452523
06/13/13 08:45 PM
06/13/13 08:45 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Eliminate it.You can do the Madd conversion in the archives or for quick I just use a screw and nut and put the 2 wires together and tape them up.Its common for the amp gauge to go bad.Mines been bypassed for probally 20 years.I run a volt meter.Problem solved.Rocky
Chrysler Firepower
Re: Amp guage burnt out! [Re: therocks] #1452524
06/13/13 09:40 PM
06/13/13 09:40 PM
N
N
That fix came to me after my panic attack!!LOL I forgot about that easy fix. The poor car has too many add ons to the fuse box and after 47 years things are starting to fry!!! I just need it to stay together for 2 hours till my daughters prom is over.
Re: Amp guage burnt out! [Re: therocks] #1452525
06/13/13 09:50 PM
06/13/13 09:50 PM
What Rock said: pull a batt cable then put both of the large ammeter wires on one of the two ammeter studs. (Dont matter which one). If there's more than 2 wires put all of em on the same stud
Re: Amp guage burnt out! [Re: RapidRobert] #1452526
06/13/13 10:34 PM
06/13/13 10:34 PM
N
N
That will work I had to solder a new end on the red wire and I bolted the two wires together, car's running all lights are on and the wire isn't heating up. Should get me thru till Sat. eve.
Re: Amp guage burnt out! [Re: newportrider] #1452527
06/14/13 09:20 AM
06/14/13 09:20 AM
Your problems are just getting started
Re: Amp guage burnt out! [Re: RapidRobert] #1452528
06/14/13 11:06 PM
06/14/13 11:06 PM
N
N
I got more faith in the daughter than the old car!!LOL I will have the wiring harness rebuilt by the time I give the car back to it's owner!
Re: Amp guage burnt out! [Re: newportrider] #1452529
06/15/13 07:56 AM
06/15/13 07:56 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
mine has an aftermarket amp gauge connected to a set under the dash. The wires were just extended to it
Re: Amp guage burnt out! [Re: terzmo] #1452530
06/15/13 08:20 AM
06/15/13 08:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just hope that after market amp gauge dosen go up in smoke.Dont ask how I know.Install a volt gauge.Simple easy and no danger like amp gauges.Just remember old Mopars draw a ton of current thru that amp gauge.Rocky
Chrysler Firepower
