Re: Need quieter air cleaner
[Re: autoxcuda]
#1452242
06/13/13 03:08 PM
06/13/13 03:08 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
Do you have a hood pad and/or a rear hood to cowl seal?
Ummmm,, No and No
Well actually I have a hood pad but haven't installed it, and have the old cowl seal but didnt intall it after the paint job, figured i'd get a new one.
[Re: MileHighDart]
#1452243
06/13/13 03:10 PM
06/13/13 03:10 PM
Posts: 1,106 Northeast
VincentVega
Northeast
how about a late model 4bbl aircleaner, with the fresh air duct. not sure where you'd route it, though. that will quiet it down a lot even if you leave the snout open to the engine bay
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: MileHighDart]
#1452244
06/13/13 03:21 PM
06/13/13 03:21 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
Ummmm,, No and No
Put those on first.
Then make a decision on the air cleaner.
[Re: autoxcuda]
#1452245
06/13/13 03:25 PM
06/13/13 03:25 PM
Challenger 1
Cincinnati, Ohio
I got old!! Years ago I reinstalled a new hood pad and cowl seal. Made my car sound way better at a intersection at a light, much quieter.
Then I went back to the stock style "tennis racket" air cleaner. lol It also makes my car much quieter and flows plenty of air as I have driven the car hard for like miles at a time out at the Bonneville salt flats for like 5 miles at a time. It never ran out of fuel or air out there on a very hot day.
Another thing my stock air cleaner does is limit the amount of evaporation out out of my edlebrock carb. Open air cleaners allow much more evaporation from my experience and take longer to get fuel into the carb.
My dorky motor...lol.
[Re: MileHighDart]
#1452246
06/13/13 05:34 PM
06/13/13 05:34 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'd look into one of the stock 340 air cleaners, no snorkels but I think they're baffled?
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: BigBlockMopar]
#1452248
06/13/13 05:46 PM
06/13/13 05:46 PM
Posts: 3,344 Central TX
roe
Central TX
Would you run fresh air ducting off the snorkel or leave it open to the engine bay?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: BigBlockMopar]
#1452250
06/13/13 06:08 PM
06/13/13 06:08 PM
roe
Central TX
Hmmm, were there ever any factory setups with ducting? I've seen some over the counter stuff at Autozone with a dual snorkel and ducting. Its chrome, maybe edelbrock... I have an open filament just like the OP
[Re: roe]
#1452251
06/13/13 06:15 PM
06/13/13 06:15 PM
MileHighDart
Lyons, CO
What ever I go with, i'll probably keep the crome Edelbrock to put on at shows, and use the quieter air cleaner for everyday cruising. Probably dont want to run any ducting, so if I use single or dual snorkle type the skorkel will be open to the engine bay. Going with the factory 340 air cleaner with no snorkels it not an option, too expensive. Not worried about correctness, or the look so much, just want it quieter for cruising with the wife.
[Re: roe]
#1452252
06/13/13 06:32 PM
06/13/13 06:32 PM
VincentVega
Northeast
sure. started around the time of leanburn. single snorkel (no air doors on the base) with a fabric type duct to a fresh air vent on the inner fender. you see them all over F/M/J bodies. 2bbl and 4 bbl. thermoquad version MAY fit AFB/AVS but I am not certain
It's round, as is the end of the air cleaner snorkel/snout. I can't recall if they were formed that way, of there was an adapter that fit into the standard rectangle. but really, I would just walk through a pick-a-part, there might be one laying in a trunk.
even if you don't hook up the duct, at least it's sealed except for the snorkel. good starting point - and cheap (although I guess you'd need to put a piece of flashing over the leanburn hole if it's one of those)
[Re: MileHighDart]
#1452253
06/13/13 06:33 PM
06/13/13 06:33 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
...just want it quieter for cruising with the wife.
You do understand that you then have to listen to everything she says right? And, even answer her every question/remark/nag during that entire trip...!? There might even be a chance you actually have to have an actual 'conversation' with her. And don't even think you can get away with an occassional "Uh huh"-reply. You're toast if she catches you doing that.
I think I'd rather listen to that open airfilter roar for some 2-3 hours myself...
