Need ways to keep my 440ci from running HOT #145189
11/03/08 06:17 PM
11/03/08 06:17 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
seems like if I run it hard, or idle for a while, it gets HOT. I am thinking of getting an auxilary fan. Is a PULLER fan at 6000 CFM enough? Any other suggestions on how to keep it cool?
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145190
11/03/08 06:25 PM
11/03/08 06:25 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
How hot does it get?
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145191
11/03/08 06:26 PM
11/03/08 06:26 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Are you relying on the stock factory gauge, or do you have a good aftermarket gauge?
What is the temperature?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Need ways to keep my 440ci from running HOT [Re: goldmember] #145192
11/03/08 06:29 PM
11/03/08 06:29 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
going down the road it sits just to the left of the middle between C and H. If i exit and idle at the light for a minute or two it creeps over and touches the H, then I start scrambling to get moving and it cools down once I get moving. I was thinking of ordering this 6000 CFM fan from SUMMIT.
http://cgi.ebay.com/ebaymotors/Flex-a-li...emZ220300891022
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145193
11/03/08 06:35 PM
11/03/08 06:35 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
How much use on the bottom end?(miles years)
How old is the rad.
I had a real over heating problem with my big block, and found the cure was in cleaning out the frost plugs and power washing the coolant passages and re coring the rad.
I thought I had re cored the rad the summer before but when my friend and Mechanic took it to his rad guy they told me that my rad had just been cleaned and painted.( it was full of stop leak all thru the engine from the old guy before me trying to stop the heater core from leaking)
Find I guy you can trust.
Thats the hardest part of all we do.
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145194
11/03/08 06:42 PM
11/03/08 06:42 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It may just be running very cool most of the time and getting up to normal temps when your gauge goes up. Check the actual temps before spending money on parts is my moto. Get a real temp gauge(non electric) and check it out or use a cooking thermometer to check temps at the radiator and compare them to the needle position on you gauge.
Re: Need ways to keep my 440ci from running HOT [Re: goldmember] #145195
11/03/08 06:53 PM
11/03/08 06:53 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
Best to see exactly what's going on before spending a bunch of money when there may not be a problem at all
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: Need ways to keep my 440ci from running HOT [Re: blairboy3] #145196
11/03/08 07:06 PM
11/03/08 07:06 PM
what do you have now for fan/shroud/wp & position of fan.
Re: Need ways to keep my 440ci from running HOT [Re: boydsdodge] #145197
11/04/08 08:13 AM
11/04/08 08:13 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
How old is the rad.
Radiator is stock, and was re-cored and flushed the previous owner said 3 years ago. I took the cap off tonight and it looks really clean. What aftermarket radiator should i get?
Re: Need ways to keep my 440ci from running HOT [Re: RapidRobert] #145198
11/04/08 08:13 AM
11/04/08 08:13 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Factory 440 setup. (stock shround and stock fan)
Re: Need ways to keep my 440ci from running HOT [Re: blairboy3] #145199
11/04/08 08:14 AM
11/04/08 08:14 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
who makes the best aftermarket gauge? or gauge cluster? already an aftermarket VOLTAGE gauge under the dash.
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145200
11/04/08 11:59 AM
11/04/08 11:59 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Before spending money on a gauge, you could check that yours makes sense first. I am lucky enough to have a friend in HVAC business with one of those laser guided, hand held temperature sensor deals. You can check just about everything with one of those: manifold temps, head, rad, water pump, hoses, block, a dogs butt....
Might be a good idea to check timing and air fuel if you can. Those things, when incorrect, can cause an engine to overheat even when the cooling system is spot on.
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145201
11/04/08 12:16 PM
11/04/08 12:16 PM
What is this in? Regardless, if the temperature gauge is operating properly then try the following fix. Go out and get a thermostat for a 440 in a motor home. This will open at a lower temp and keep the car from initially heating up. I would also suggest you run a radiator flush. Not for the radiator, but the block. The engine cooling ports could be clogged or semi clogged. If you don't have a fan shroud, invest.
If it heats up when driving on the highway this screams of pour cooling circulation. It would just plain overheat if the thermostat wasn't opening.
Good luck
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145202
11/04/08 03:45 PM
11/04/08 03:45 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
going down the road it sits just to the left of the middle between C and H. If i exit and idle at the light for a minute or two it creeps over and touches the H , then I start scrambling to get moving and it cools down once I get moving.
If you have a fan clutch it is time to replace it. It's not working anymore.
Note if you have a 4 core the new replacement units are too tall (will hit the radiator) to put in. Use a Hayden 3665 or a 2765. I think it was $39
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Need ways to keep my 440ci from running HOT [Re: HealthServices] #145203
11/04/08 04:24 PM
11/04/08 04:24 PM
So Cal
So Cal
http://search.harborfreight.com/cpisearch/web/search.do?keyword=infrared+thermometer&Submit=Go
These things are cheap enough everyone should have one. I bought mine back when they were still well over $100
They help when you are diagnosing a overheat problem and tell you where the hot spots are.
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145204
11/04/08 07:39 PM
11/04/08 07:39 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
In my 66 Coronet with a 440, I used one 16" electric puller fan and still had heat problems sitting in traffic on hot days. I added a second 16" pusher fan on the other side of the radiator and now I can sit in 90+ degrees traffic all day and never get over 205 The second fan does not turn on until the temp reaches 200. I offset the fans for max coverage on the radiator core. You can get quality 16" fans for $100 each.
Re: Need ways to keep my 440ci from running HOT [Re: HealthServices] #145205
11/04/08 08:53 PM
11/04/08 08:53 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
here are some pics, let , me know what you think.
Re: Need ways to keep my 440ci from running HOT [Re: Lefty] #145206
11/04/08 08:57 PM
11/04/08 08:57 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
id like to do that but have a cooler on the front side and that fan and shroud on the other side- what would I have to do?
Re: Need ways to keep my 440ci from running HOT [Re: AHall] #145207
11/04/08 09:04 PM
11/04/08 09:04 PM
IN
ahy Offline
ahy  Offline
IN
Heating up at idle sounds like not enough air. The pics show what looks like a "standard" 5 blade fan. A cheap upgrade would be a 7 blade fan from a mid-late 80's Cordoba or the like. I've got one from a core 400. It is about 19.5" diameter and has 7 large blades with cupped ends. Along with a fresh clutch, it should help in the air flow department.
Bouchillon Performance also sells a high capacity 6 blade.
Re: Need ways to keep my 440ci from running HOT [Re: ahy] #145208
11/04/08 09:12 PM
11/04/08 09:12 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Is this it?
http://www.bouchillonperformance.com/BPE220618.asp
